dimitrisx
Guest Wifi from hAP ac2 to hEX router
Sat Jun 19, 2021 7:51 pm
Hello everyone,
I am owner of a mikrotik hEX, as my main router with firewall, dhcp etc. ether1 is the wan port that takes internet from an isp router and two hAP ac2 as access points only, they don't have dhcp, only an IP/DNS and a bridge that contains ethernet ports and wifi) and I would like to implement a guest wifi to my two hAP access points.
In hEX, I made a second bridge, second DHCP server, vlan20 assigned in the second bridge and in ether4 and ether5 (connected the hAP ac2)
Also, in hAP access points i made a second bridge and assigned virtual Guest WiFi and vlan20, with vlan tag id: 20
But when i am trying to connect to guest wifi, i don't take IP.
Every tutorial i have checked, implement that in router that has built in WiFi.
How can i complete that? What i am missing?
anav
Re: Guest Wifi from hAP ac2 to hEX router
Thu Jun 24, 2021 2:18 pm
Hi there dimitri,
What you are asking to do is very explained in this article.
You only need one bridge and simply make as many vlans as you need to carry traffic.
vlan10-home (home traffic)
vlan20-guest (guest traffic)
vlan30-devices (device traffic, thermostats cameras etc)
vla40-media (NAS, firestick, appletv etc).
viewtopic.php?f=23&t=143620
Define each vlan with interface being the bridge
Each vlan gets four things: IP pool, IP address, dhcp server, dhcp server network
Assign Bridge ports settings (trunk ports to hapac devices carrying all the vlans you want to send to the hapac)
Assign Bridge vlan filtering settings
Adjust firewall rules
APPLY bridge vlan filtering enabled as last step
anav
Thu Jun 24, 2021 2:19 pm
edit: duplicate post
Users browsing this forum: No registered users and 18 guests
