cptbill
Chateau LTE12 setup to use external lte antenna
Wed Jul 28, 2021 12:12 am
newbie question here (first time experience with mikrotik)
i got the Chateau LTE12 recently, works nice. I decided to buy after a few days the MikroTik MTAO-LTE-5D-SQ mANT LTE antenna.
Problem is that i cannot find the option to make the Chateau to use the external antenna.
Under the lte option where i should have the option for external antenna, there is nothing on my mikrotik. I am running the 7.1beta6 fw (factoty version was .1beta5)
Any help?
infabo
Long time Member
Long time Member
Re: Chateau LTE12 setup to use external lte antenna
Wed Jul 28, 2021 2:05 pm
This is a bug apparently. You can set antenna in Quickset too.
rextended
Wed Jul 28, 2021 2:11 pm
Chateau LTE12 factory and ONLY supported versions are 7.0beta6 or 7.0.2 or 7.0.3 as MikroTik staff says.
If you see 7.1betaX something as put wrong beta firmware for that device.
USE SEARCH FUNCTION FIRST instead of open useless duplicate topic
Until your argument was not present, it was the first result "Chateau LTE12 External Antenna":
viewtopic.php?f=2&t=176457&p=868619&hil ... na#p868619
Users browsing this forum: phascogale, sch and 63 guests
