useruser1212
failed to register a network
Mon Aug 02, 2021 3:31 am
Hello dear users of mikrotik forum, i have a LHGG LTE6. And it seems i get some problems with it.
Usually at night, the antenna disconnects from the network,it shows tx and rx disabled, then after some time the antenna connects to the cell tower again and i have internet again, and this happens over and over again. I still have internet most of the time, but this problem is very annoying and i would like to get it fixed. I will upload the screenshot of the logs
At first i was thinking i loose the internet connection because of some trees blocking the point to the tower as the wind blows but i do not think this is the case. My issue is very close to this, almost identical i would say
viewtopic.php?f=7&t=172750&p=844571&hil ... rk#p844571
I am going to write to support, but if there is some quicker solution it would be appreciated. Maybe this issue will just get fixed in the next update and i can just wait ?
Everything is updated to the stable version.
WeWiNet
Long time Member
Long time Member
Re: failed to register a network
Mon Aug 02, 2021 1:01 pm
have you updated latest LTE firmware already?
I had these issues on some older FW, but now this is gone.
Would be good to show export of your LTE settings.
useruser1212
Mon Aug 02, 2021 9:16 pm
Yes its the latest firmware R11e-LTE6_V027
Would this help, or count as an export of lte settings ?
pin-status: ok
registration-status: registered
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE6"
revision: R11e-LTE6_V027
current-operator: xxx
lac: 661
current-cellid: xxx
enb-id: xxx
sector-id: xxx
phy-cellid: xxx
access-technology: LTE (CA2)
session-uptime: 17m52s
imei: xxx
imsi: xxx
uicc: xxx
primary-band: B20@10Mhz earfcn: xxx phy-cellid: xx
ca-band: B3@20Mhz earfcn: xxx phy-cellid: xx
rssi: -68dBm
rsrp: -103dBm
rsrq: -16dB
sinr: -5dB
Users browsing this forum: No registered users and 31 guests
