elipsa
SXT LTE 4 replacement
Sat Aug 14, 2021 12:41 pm
I use SXT LTE KIT with LTE cat. 4. I use it in rural area with BTS a little more than 3 km from me. In general, the connection is quite stable (status GOOD im MT), but speeds I get are not very satisfactory - on average it is 3-4 Mbps DOWN and 7 Mbps UP. I was testing various channels, seems that B1, B3 and B7 are the best, however there is no significant difference between each od them. B20 is very poor, so I do not use it at all.
I consider buying the LHG LTE cat. 6 instead. Can I assume better results with this one in sense of higher speeds? There is also LHGG a little more expensive, but not sure if it is worth overpaying in my situation.
Did anyone perform migration from SXT to LHG to deal with the feedback?
sthen
Re: SXT LTE 4 replacement
Mon Aug 16, 2021 6:33 pm
The dish in LHG/LHGG isn't good for B20, but would help improve signal on the higher frequency bands. CAT6 might help if the provider allows channel aggregation- out of the bands you mentioned and ignoring B20 which wasn't working well for you, it looks like the only supported 2CA band combination with the R11e-LTE6 are B3+7 (check "supported 2xCA bands" in https://i.mt.lv/cdn/product_files/SXTLTE6_200836.pdf). But there are some firmware problems see e.g. viewtopic.php?f=7&t=173909. So you might get better speeds, but you might just get more problems... LHGG is a faster router but same LTE6 card, I think it will only really help if you have a fast connection to the mobile network.
Zacharias
Mon Aug 16, 2021 7:52 pm
Cat 6 LTE supports carrier aggregation, meaning it can use more that 1 bands at the same time, thus providing better performance results...
However, even for a Cat 4 LTE, your speeds are very low...
Users browsing this forum: 4wojtek5, davordaco86, volkirik and 79 guests
