MUM Europe 2020
boardman
Bonding or dual nstreme asking for suggestions/recommendatio
Tue Aug 21, 2007 6:05 pm
Hi there
We have the necessity of upgrade one of our links, that link carry our main internet feed, this link is about 3 miles long, this is due we are currently topping up it available bandwidth.
This links consists of two RB532's w/SR5's an 27 dBi hyperlink's grids, usually connected @54Mbps, the real throughput of this link is around 18-22Mbps Half duplex
So the idea is to upgrade this, and here's the big question and I am asking for your recommendations and experience.
- Option 1: Use a uATX intel mobo w/2.0 Ghz Core 2 Duo cpu, 1 GB RAM, 2 pci to miniPCI adapters a XR5 for TX and a CM9 for RX, all this connected to a PacWireless HD Series Dual polarization dish using dual nstreme. (Per side)
- Option2: Use two RB532's with one XR5 on each RB, Nstreme, same Pacwireless HD Series Dual polarization dish, one RB+XR5 connected to Vertical feed, the other RB+XR5 connected to H pol feed, then do bonding of these two links in a third RB532 board. (Per Side)
Which one of these two setups will give me best throughput?
Which one of these two setups will give us better reliability?
I have clear option2 two is a lot easier to implement, because option1 requires a bigger nema box up in the towers, requires ventilation, requires AC voltage upthere instead of PoE....
Best Regards
Jorge Boardman
LaredoNet - Mexico
akoe
Re: Bonding or dual nstreme asking for suggestions/recommendatio
Wed Aug 22, 2007 1:37 pm
i suggest 1 option
we done that....with 5 miles, we use 2 cm9,2 mini pci to PCI, 2 antennas grid 27 dbi, and 1,8 Ghs mobo.
and it's work verrrryyyyyyy good, till now its 1st year.
bw.....no problem, rate transfer ..the best we have till now.
boardman
Wed Aug 22, 2007 7:10 pm
i suggest 1 option
Thks for your reply ... anybody else...
Gerard
Trainer
Trainer
Wed Aug 22, 2007 8:46 pm
option3: simply replace the RB532's with RB333's.. Using nstream and regular 5ghz I'm able to get ~34 mbit tcp half duplex..
option4: setup a dual nstream link with a single RB333 and 2 cards on each end and get ~65 mbit tcp using that dual pol dish from 1&2..
option5: wait for the RB600 series and get even more bandwidth from a dual nstream link..
-Gerard
mcozio
Thu Aug 23, 2007 12:44 am
take 2x core2duo, 512mb ram, 4x wmia123ag, nstream2 , 5g-turbo - score - 77-80mbps full duplex, mt 3.0beta10 tested
abc123
Thu Aug 23, 2007 4:59 pm
... but you had it indoors and that's totally different than going to real world and trying to consume 80MHz of scarce bandwidth ; not speaking about fact that those 80MHz are more like 100MHz really due to bandwidth overflow.
Users browsing this forum: No registered users and 17 guests
