MUM Europe 2020
ccr
Channel Cloaking with XR2
Tue Aug 28, 2007 8:50 pm
Has anyone successfully used an XR2 with the 2-10 or 5-10 bands? It act wierd when I try to test.
tgrand
Long time Member
Long time Member
Re: Channel Cloaking with XR2
Wed Aug 29, 2007 5:30 am
Yes,
Signal Quality calculations appear to be incorrect.
They appear to be calculated based upon the datarates of a full 20MHz channel width.
That said, links have been as reliable as B only mode, but much faster data rates.
Equis
Forum Veteran
Forum Veteran
Thu Aug 30, 2007 2:54 pm
I do it, works fine for me.
What strange thing did it do for you?
I have been told you need a good power supply tho.
ccr
Wed Sep 05, 2007 6:44 pm
Well
1. Have an 532 board with SR9 and SR2. The SR2 is in the band 2GHz-10MHz. When doing testing I swapped the SR2 with the XR2 but everytime I tried to switch to the correct band the 532 board would reboot.
2. Then I put the SR2 back in and build a new unit with a 532 board and XR2 and tried to get it to connect to the SR2 in station mode. It would not!
3. Then I tested the normal 2.4 band for WiFi and it worked fine throught the XR2 [you can crank some serious power out of those!].
Conclusion - XR2's will not be put into production at this time.
Gerard
Trainer
Trainer
Wed Sep 05, 2007 10:56 pm
Did you turn the TX power over 18? If so that could cause your rebooting problems.. Also what voltage power supply did you use?
I have close to 200 XR2's in use, approx 40 of them are in 532's on towers.. All of them are using 5 or 10mhz channels with no problems.
-Gerard
ccr
Mon Sep 10, 2007 6:49 pm
Thanks for the info! At least I know that it will work. I will try with another card and see what happens. The rebooting was happening with 532/48V POE/I may have turned that power up over 18, this was the first time I had used the XR2 and didn't realize that they are different in terms of power levels.
itchibahn
Mon Sep 24, 2007 4:32 am
-Gerard
Gerard,
What power supply rating would you recommend if you were pushing over 18?
Users browsing this forum: TruthPaste and 29 guests
