MUM Europe 2020
flex
2 minipci cards on a single board p2p link suggestion needed
Tue Aug 28, 2007 11:44 pm
I need advise on setting up two p2p links at 5ghz freq. One link is 32km and the second one is 50km.
The situation is: location A --50km-- location B ----32km--- location C
On all locations I have 1.2 parabolic dishes.
On the 50km link I might have 1.5m parabolic dish need to to check on that. (long story)
The problem that I am facing is that on location B there is frequent power outage and I need to reduce the power consumption of the equipment at that location in order for the equipment to run longer through UPS.
My question is will I be able to achieve the above links with two r52 cards on a single rb532 board at location B
If not I would appreciate any suggestions on single board with dual cards in order to achieve what I am looking for or maybe dual boards with low power consumption and minipci cards with lower power usage. But I would prefer the single board for better problem solving in case of any problems.
Thank you to everyone for the help.
Alex
Equis
Forum Veteran
Forum Veteran
Re: 2 minipci cards on a single board p2p link suggestion needed
Thu Aug 30, 2007 3:01 pm
Yes, that will work
however, I would use a battery and charger not a UPS
You can get 24 hours uptime from a 18ah SLA
Gunzoid
Fri Aug 31, 2007 3:47 am
400 ah gel cell or AGM battery bank with a 4 amp trickle charger works great for flakey AC power situations. 12 vdc right off the batteries to your board.
steveloomis
Thu Sep 06, 2007 3:21 pm
I wire in external large batteries to a UPS. Much simpler than charger and battery. UPS will charge external batteries. Add batteries increase battery size to get necessary run time.
Users browsing this forum: SiB and 23 guests
