RobClem
RB333 speedtest help
Mon Sep 10, 2007 10:09 pm
Hi, just testing a pair of rb333 V3rc4 with 2 R52 cards running nstreme2
I have good signal levels on RX and TX but everytime I run a UDP send test I get kicked off
when I run a receive test I get 60Mbps :-)
when I run a receive or SEND TCP test it works although throughput not quite where I want it.
everytime I run BOTH of SEND UDP one end usually reboots or kicks me off the winbox session
any ideas?
thanks
Rob
uldis
Re: RB333 speedtest help
Wed Sep 12, 2007 10:06 pm
I suggest to use another two routers/pcs for bandwidth generators, as when you do it directly between both boards it consumes lot of CPU power for generating traffic and not for doing something else.
Also try to disable the connection tracking and chack the results.
Users browsing this forum: Bing [Bot] and 36 guests
