mushmx
Trouble with link point to point 64km
Sun Nov 18, 2007 3:11 am
Hi, well i had a trouble with my link point to point of 64km, I using
2 Router 532 with Wlan card higher again
2 heavy duty 28dbi
2 Tower of 60mts high.
When i do the link TX/RX : 72/77 and TX/RX: 24/36mb for 5 or 10 minute work very well, but the next day my link is very intermittent and the TX/RX increment to 92/95.
What is wrong? is very far 64km?
Note: I used TX Power (Default, 20, 24, 26, 28, 30) but nothing fix the problem.
skillful
Trainer
Trainer
Re: Trouble with link point to point 64km
Sun Nov 18, 2007 11:14 am
check your pigtails and connectors for loose or partial contact.
chvdr
Sun Nov 18, 2007 12:44 pm
hi there!
you can find many posts onto the forum with that treatement. but i think that you have a porblem related to cables, antennas, etc. signal levels <if they perpetual, ofcourse> are quite enought to pass 30Mbps of traffic. we have similar link tx/rx=72/72 with 25Mbps full duplex.
Best regards,
C. G.
If nothing to say, do not say anything...
All thoughts that have huge effect actually are simple...
galaxynet
Long time Member
Long time Member
Sun Nov 18, 2007 5:56 pm
mushmx -
Where did you get these 'default' power settings from? I know of no wireless card that does 30db.....
If you manually set the power out of the card(s) to those you listed above you most likely damaged the cards and will have to get new ones.
Since you are using a RB532 and high power cards I am going to guess that you are using XR5 or XR2 cards. In a RB532 you have to set the power at 10 less than you actually want - like this - if you want 26db out then you need to set the power manually at 16. If it were me I'd just let the RB set it to default and leave it at that.
If it worked one day and not the next then;
1) If the cards are not damaged then it could be a cable/connector problem.
2) If you have had bad weather lately it could water intrusion in to the cable, connector, enclosure or a combination of any of the three.
3) Bad weather again - possibly the antennas were moved by high winds?
Thom Lawless
General Manager
RapidWiFi, LLC
thom.lawless [at] rapidwifi.com
mushmx
Sun Nov 18, 2007 8:53 pm
Thank you for your pots.
The situation is very rare because we changed all one by one and we tested in every change in both towers and currently are new.
The last weekend the weather was raining and fast wind but this week the weather was sunny and not wind. We did the next changes in this order:
1.-the cable rj45
2.-Coxial cable
3.-Pigtails
4.-Heavy Duty
5.-RB532
6.-The position of the antennas
Good Link
MB tx/rx: 24/36
Signal tx/rx: 72/77 (Sometimes with this signal we try it pass a file "400mb" from tower1 to tower2 and the link is broked, but if we do the same from tower2 to tower1 the transfer is passed) :(
Bad Link
MB tx/rx: 6/12
Signal tx/rx: 92/95 (Link Broked)
One router are damaged, I suppose because the TX Power was higher (TX Power Manual = 30)
My wlan card are Mikrotik SR50 (300Mw)
With all these change the link continue intermitent.
chvdr
Sun Nov 18, 2007 10:08 pm
what actually card you used
Best regards,
C. G.
ghmorris
Sun Nov 18, 2007 11:28 pm
2 heavy duty 28dbi
I see you are in Cancun. How much of this link is over water?
Tidal variation can make a big difference in link quality.
You also have very little fade margin for a link of this length. Normal variation in signal strength would be enough to take the link down.
In a tropical environment rain fade at 5.8GHz is also a factor on very long links.
Are you running RB52H cards?
George
doush
Long time Member
Long time Member
Mon Nov 19, 2007 12:56 am
1- be sure about the cards you use.. SR series are 400mW cards..
2- Do not change the default tx power settings, leave them default
3- Enable Nstreme on both sites
(4- Check for rarely used channels like ch 14 for less intereference )
WirelessRudy
Mon Nov 19, 2007 2:33 am
So, under certain conditions your link becomes marginal, resulting in dropouts
I would first look to the path of the radio signals. Are the towers high enough for such distance? Only LOS (Line of Sight) is not enough, think about the fresnell (´belly´ of the signal path) that has to stay clear of any or most objects (trees!).
In this relation, a path over water with its tidal differences can make a difference.
Then, radio signals are always influenced by atmospheric conditions like moisture, rains, snow, temperature etc and even day or night, or more specially dusk and dawn. With strong connections -70 and better, this would normally not be such an issue but I think your best link connectivity is pushed in the marginal condition under some conditions.
And yes, don't push your cards to much. Max. power outputs of the cards will overheat it resulting in unstable performances (that might also be the reason of your drop outs) and finally death. Leave setting to or close around the default 17dbm.
mushmx
Mon Nov 19, 2007 2:47 am
Hello George
The link not crooss over the sea or lagoon is just jungle. And sorry for the bad information of the wlan card, actually i'm using the wlan card RB52H (350mW) and is very rare because I have a link point to point with the same feacture over the sea (Playa del carmen to Cozumel Island) and working without trouble the only diferent is the distance "40km".
Hello Doush
Yeah i was worng, the wlan card are RB52H.
The tx power actually is 26 because with default haven't link, only with 26 i can do the link, also i changed the frencuency.
never happend me this situation. The next test are uses an other antennas with more dbi if this not working mmmm maybe be install and other point between the 2 tower.
Cancun <--------------->Playa del Carmen (64km) "Current Link"
Cancun <---->(30km) Pto. Morelos <-----> Playa del Carmen(34km) "Alternative"
promind
Mon Nov 19, 2007 9:42 am
Hello George
Hello Doush
try xr5 and write back.
I have exactly the same problem.
2 days with very good signal -50/-48 26km link with r52h then -88/-48
replaced 1st r52h with zcom 622XA and singel reduced to -75 a few days later replaced the other r52h with xr5 and signal is now -49/-41 -> 2 weeks no change
doush
Long time Member
Long time Member
Tue Nov 27, 2007 2:42 pm
did you guys tried enabling Nstreme (not dual) ?
It helps a lot especially in long distances...
onowojemma
Sun Dec 30, 2007 7:37 pm
Hello My Gurus
pleas am searching the Mikrotik manual on how to enable Nstreme not dual but have not seen any thing on it can some one help me out.
thanks in advance
Mikrotik! making networking easy
jwcn
Sun Dec 30, 2007 11:30 pm
It's in the manual under wireless interfaces.
shielder
Mon Dec 31, 2007 8:50 am
maybe because of the rain fade that makes your link unstable.
and i don't think 60 meter tower would be high enough for 60 km link. it would be some how unstable.
tgrand
Long time Member
Long time Member
Wed Jan 02, 2008 4:57 am
What are you usng for power supplies?
Tanker
Sat Jan 05, 2008 7:02 pm
Again - just my 02 cents worth...
It is either a bad LMR.. or...
Bad Power Supplies...
We've had a couple of these instances and every time it's turned out to be as above
- LMR wet or badly made
- rubbish Power suppy with fluctuating voltages.
Of course - as you change up to XR5's.. the more power (wattage) required. We've found that by using "clean" power - 12V - from a battery solves this issue. We have long distance links (~70Km) and we cannot afford to be running after this type of thing.. and have done extensive testing to stop these issues.
Operating off 48V doesn't help either - imho - because of the losses over the on-board transformer.. but.. like I say - my opinion only and that's why we decided to run the boards on 12V.
It's an irritating challaenge - but once you've nailed it it'll all come together.
Regards
BobcatGuy
Sat Jan 12, 2008 10:52 am
[/quote]
replaced 1st r52h with zcom 622XA and singel reduced to -75 a few days later replaced the other r52h with xr5 and signal is now -49/-41 -> 2 weeks no change[/quote]
Just wanted to pont out that there was another RB52H that had good signal, then suddenly dropped signal significantly! Mine did that as well, actually 2 days as well. Was there a problem with RB52H that we did not know about? And I thought I messes sompthing up!
Makes for a good short range testing card, thats about it!
mushmx
Sat Feb 09, 2008 7:55 am
Finally I did the link point to point, well I used 2 card XtremeRange of 600Mw into my routerboard 532 mikrotik, but something rare happened when I increased the TX POWER of AP BRIDGE, the router began reboot until that I connected via telnet mac to reset it.
In the side of STATION WDS I can increase the TX Power to 20 no more because then the AP Bridge began reboot. so finally we decided the next configuration:
STATION WDS:
TX POWER: 20
"MANUAL TXPOWER"
Processor router: 333MHZ
AP BRIDGE:
TX POWER: DEFAULT
"REGULATORY DOMAIN"
Processor router:333MHZ
We got it the next result STABLE:
TX/RX RATE: 18Mbps.
TX/RX TRANSMISION: 80/87
I think the problem maybe are the antennas "Heavy duty of 28dbi" and we need others kind of antenna with more DBI to get a excellent link.
EQUIPMENT:
2 ROUTERBOARD 532
2 XTREMERANGE 600Wm
2 Antenna heavy duty of 28dbi
1 tower "AP BRIDGE" 80mts.
1 tower "Station WDS" 60mts.
Distance 64kms.
How I can increase over the TX POWER?
RK
Long time Member
Long time Member
Sat Feb 09, 2008 12:50 pm
How I can increase over the TX POWER?[/color]
You are supposed to use default power. You can burn your device and get poor performance if you mess with the power settings.
mushmx
Sat Feb 09, 2008 5:15 pm
Thanks for the reply.
So if I can't increase the TX POWER, I need use other antenna with more DBI?
The distance is 64km and I've 2 tower (cancun tower 80mts High - Playa tower 60mts high)
chvdr
Tue Feb 12, 2008 7:42 am
ofcourse, much bigger antenna is an obligation. 64km is serious long distance and good antenna dimension is ab. 2m. and above.
appropos, how bigger is yours? 28dBi is quite little dish... very small.
Best regards,
C. G.
Tanker
Wed Feb 13, 2008 12:13 pm
A 2 meter antenna 80 meters up is going to be FUN!!!! - NOT...
If you could just lift your Side B to ± 80 meters as well you'd be able to establish a good link using normal grids
I've done a Fade margin Calc and Fresnel profile and it could work
Let me know if you need some more help.
T
chvdr
Thu Feb 14, 2008 12:03 am
it's not "FUN!!!!"... it is possible. believe me. futhermore, originally mushmx said
... "If you could just lift your Side B to ± 80 meters as " us much more funnest.
Best regards,
C. G.
mushmx
Wed Apr 23, 2008 4:59 pm
Hi everybody
Thank's for all reply, I continue with this link :shock: and I read all the post but i have a doubt about what model, kind and mark of antenna i need buy? no matter if is european or american product.
Thanks, best regard. :lol:
Belyivulk
Thu Apr 24, 2008 8:02 am
Sounds to me like the 350mW cards are broken. We have had this happen MANY times with R52H
chvdr
Fri Apr 25, 2008 8:27 am
yes, every time we replace antenna cables and wless cards. i suppose, it is COMPULSORY when you search what is goin' on in same case or related.
Best regards,
C. G.
awamex
Sat Apr 26, 2008 12:42 am
Hi chvdr and Belyivulk
It's me mushmx 8) thank's for the reply but what kind and mark of antenna recommend me to use with this link? and if you know some website please post it.
Belyivulk
Sat Apr 26, 2008 12:44 am
we have a 58km link here in NZ, with Mikrotik 30DB Dish antennas, R52H, Mikrotik Pigtail & LMR400. We get -69 / -71 for signal
awamex
Sat Apr 26, 2008 4:37 am
Thanks for the reply Belyivulk
I'm using the next equipments:
2 Routerboard 532
2 Wireless card XTREMERANGE 600Wm
Distance 64kms.
The situation is very rare because I got a excellent link between TX/RX 60-70 with 18/24Mb transfers but inexplicably the link become degrade until to dead signal and the only reason that come to my mind is that some signal of the airport is interfering with my link :? so I checked all cables, pigtail, router, antenna, etc.... and nothing repair the trouble, so I think maybe if I change the antenna to other with more DBI like 36dbi maybe repair the link.
What do you thing about this?
Note. mostly the link cross the jungle and the only build is the airport and we are a sea level.
Heri
Belyivulk
Sat Apr 26, 2008 4:50 am
What frequency are you using? 57xx?
Have you tried the frequency usage tool? What is your noise floor when the link is good? what does it become when it gets bad? What is the humidity like? What time of day does the link go bad, and for how long. How do you fix it? What type of cable are you using from the pigtails to the antennas? are you weather sealing it correctly?
These are all questions i need answers too, lol
awamex
Sat Apr 26, 2008 5:31 am
I'm using the band 5.8ghz and frequency 5822
Heri
Belyivulk
Sat Apr 26, 2008 5:32 am
Try using a lower frequency, 5745, or even to test, set your country to germany and use 5500 (to test only)
If your link stays up you can be sure the problem is interference, if not, you know the problem lies elsewhere
awamex
Sat Apr 26, 2008 6:25 am
Ok, I'll do the test the next week.
Thanks Belyivulk :D
Belyivulk
Sat Apr 26, 2008 7:14 am
No worries :)
The other thing is time. Does the link go down first thing in the morning after sunrise?
awamex
Sat Apr 26, 2008 6:57 pm
No worries :)
The link go down without matter the time is variable :(
Users browsing this forum: Corin and 26 guests
