bejcd
bandwidth limitation on RB500 ...
Tue Dec 11, 2007 10:23 pm
I have installed 3.0betaRC11 on RB500+CM9 as AP-bridge(wds enabled) and 10 Mktk station-wds clients so pretty straightforward configuration model (Nstreme is not enabled).
If at least 3 clients utilize ~2Mb/s per client (simple download) what makes 6Mb in total on the RB500 Access Point the available bandwidth of that AP doesn't exceed ~ 100kb/s + extremly high ping time on every client (latency issue).
Point-to-Point (Bridge <-> station-wds) works well and doesn't have the same issue.
Does anybody experience the same problems and how to improve AP capability to handle in that scenario 10 wireless clients x 2Mb = ~20Mb in total through wlan1 interface ?
Frankly, I have never seen RB500 + Mktk ROS in AP-bridge mode to be able to handle more than 6Mb/s ! Maybe this is a real limitation of that board or a certain limitation of an Atheros card itself.
Described problem is the same with ROS ver. 2.9.x
Hope somebody will answer this posting.
Thank you,
D.
jonbrewer
Re: bandwidth limitation on RB500 ...
Tue Dec 18, 2007 10:20 am
On a RB532, use 2.9.50 and NStreme. We have boards that are happy up to around 20mbps aggregate (half-duplex) traffic in multipoint settings. Each sub is rate limited and all are connected at 54mbps, so there is no contention for wireless bandwidth.
bejcd
Sat Dec 22, 2007 6:03 pm
I think I haven't completely understood the explaination "20mbps aggregate (half-duplex) traffic in multipoint settings".
Would you be able to detail the words.
Thank you for the response,
D.
Users browsing this forum: Amazon [Bot] and 52 guests
