MUM Europe 2020
prawbros
Nstreme Problems!
Fri Dec 28, 2007 5:30 pm
Hi All, I have looking around this forum but I think I can't get an answer for my question. I'm using RB133 with R52H (High Power) on both sites, but when I turn the Nstreme on, the link goes up and down. Why is this happen? My link is only 1.5 Km and LOS. I'm using Grid 24DBi and Andrew F1PNMNM Jumper. Or have I miss something in this forum? Thanks before.
Andre Prawira
sten
Forum Veteran
Forum Veteran
Re: Nstreme Problems!
Fri Dec 28, 2007 6:43 pm
Are you trying to use Compression by any chance?
Move along. Nothing to see here.
shielder
Sat Dec 29, 2007 6:56 am
try posting your configuration here.
and please remember, you need to enable nstreme on both AP and client
t3rm
Sat Dec 29, 2007 12:14 pm
It'll be better to post the Status of Wireless
RX/TX Signal, CCQ, etc ..
I guess Andre coming from the same country as me.
So perhaps he had interference the same like i do .. 8)
prawbros
Sat Dec 29, 2007 8:19 pm
Sorry, I can't enable Nstreme, because the link is already up and running now. for the script, I will post it some other time, thanks for your attention shielder. I'm not using any compression for your information, and hello t3rm: my ccq is 90-100/100. the Signal is about -55. For now, I'm using Router OS v2.9.49, is it possible because of the version? Hmm, Does anyone have the same problem with me? Thanks once again.
Andre Prawira
jwcn
Sun Dec 30, 2007 11:27 pm
Is the signal -55 on both ends?
prawbros
Mon Dec 31, 2007 4:56 am
Yes, it's on both ends. -55 and -52. Do you have any suggestions? Thanks.
Andre Prawira
jwcn
Mon Dec 31, 2007 6:19 am
Can you post your entire configuration.
shielder
Mon Dec 31, 2007 8:43 am
maybe because u are using RB133 + r52h.
try changing to RB333 or use a PC as your wireless device. it's all because of the processor power or the board.
t3rm
Wed Jan 02, 2008 11:47 pm
Andre:
Try to lower the TX Power.
I have the same problem like you on my RB333 - R52H
But personally i prefer not to use Nstreme because it only able to burst a little much bandwidth, (only around 1-2Mbps higher) but you sacrifice the latency lots.
The latency i have in here change from 1 - 2 ms into 10 - 50ms unstable, when using Nstreme.
8)
prawbros
Tue Jan 08, 2008 10:07 pm
Sorry, haven't got the time to be online.. :) Hmm, is it because of the processor power? Maybe its not because the configuration. Because at first I'm using Nstreme, it was okay but after some time it started disconnecting, is it possible because of the rain and wind? Thank you for your kind attention.
Andre Prawira
Equis
Forum Veteran
Forum Veteran
Wed Jan 09, 2008 12:07 am
I dont think its processor
I would guess interfrenece.
illiniwireless
Tue Jan 15, 2008 1:16 pm
I had the same problem you are discussing. My clients are working fine without nstreme but with it they deauthenticate and reauthenticate continously. I gave up on it but if there is an anwser I would like to try it. I am using rb600 for ap and 133c for client. Both units have the same software (3.0rc13).
prawbros
Thu Mar 06, 2008 7:45 pm
Thanks Guys for the reply you all gave to me, sorry I havent active for long time. In the end, I use only WDS.. :( if there is any news I'll post it again here.. Thanks all.
Andre
jdejansb
Sat Mar 15, 2008 2:46 am
I have the oposite problem : nstreme works fine, and when I switch it off, the link is fine (connects, same signal, everything seems to be oK), BUT - no traffic ?!?
Both MTs are 532s... One has 2, and the other has doughterboard with 2 more cards (all-in-all, 4 cards). Some are winstron cm9 and some are compex wlm54g. On both sides of the link it is compex card ...
Any suggestions???
Dejan.
jdejansb
Sun Mar 16, 2008 12:54 pm
Any suggestions???
Dejan.
AnyOne ? HElp ?? :(
jwcn
Mon Mar 17, 2008 5:30 am
Can you mac ping?
jdejansb
Wed Mar 19, 2008 9:31 am
Can you mac ping?
Hmm, I didn't try... But I couldn't mac-telnet second time I tried to turn off nstreme; I guess mac-ping wasn't working too ..... What does it meen if mac-ping works, and there is no IP traffic?
D.
nowires
Wed Mar 19, 2008 11:34 am
NStreme must be enabled or disabled on BOTH SIDES to work.
ilius168
Thu Mar 20, 2008 2:52 am
i find that when using nstreme loaded with traffic, latency becomes stable.
but would anyone suggest what is the best setting for using nstreme?
Users browsing this forum: judgezn and 43 guests
