ncrossley
Network Problem, Speed not there
Fri Jan 18, 2008 7:00 pm
1 X Omni Directional 900mhz
1 X XR9 Wireless Radio/8 port MiniPCI/PCI adapter
1 X x86 1.3Ghz based routeros system
12X RB133C3/XR9 Combo Client units
Configuration is as follows.
AP Configuration: G Mode
The AP is fed from a 10mbit dedicated connection Hardwired into the LAN port.
Created a Bridge interface while in AP Bridge mode.STP Enabled. Ether1 as only port.
Set to Dynamic WDS.
IP Address of the Bridge/AP is 192.168.200.20 /16 subnet
12 Client units connecting to AP Unit.
Average signal of -75
Client Side Config
Created Bridge. STP enabled. Ether1 and Wlan1 as the ports.
IP Address set 192.168.200.21-33 /16 subnet
Connections stay stable but speed varies from 18kbps -> 7mbps
jwcn
Re: Network Problem, Speed not there
Sat Jan 19, 2008 5:22 am
Don't make duplicate posts.
Users browsing this forum: Baidu [Spider], heidarren and 22 guests
