xbaha
bridge in v3 not working like before
Fri Jan 25, 2008 11:09 pm
i have 2 RBs, in both RBs here is what i did
created bridge1, then added eth1 & wlan1 to the bridge ports, on previous versions, i was able to ping the IP of the other RB from winbos, after upgrading to version 3, i get request time out.
has anything changed in version 3 in regard of bridging ports?
thanks.
jordantrx
Long time Member
Long time Member
Re: bridge in v3 not working like before
Fri Jan 25, 2008 11:43 pm
How are you connected? we need more detail on what is going on, yes in v3 They did change bridge up a little bit, it is no longer forwarding it is designated port. If you are trying to ping wlan1 i would suggest hooking up a connection to wlan1 with say your laptop or whatever. Use wlan1 then ping it... not sure if this was what you were asking because of none detail.. -Jordan
~Agricultural WISP "ZONE"~ Beware of oncoming cattle and dont hit the farmer!!! I need to ask him about using his silo for an AP first"~
*Automated Billing Installer* http://wiki.mikrotik.com/wiki/AutomatedBilling Built by Krige ;-)
bokili
Sat Jan 26, 2008 3:31 am
thanks.
Choose STP protocol when creating bridge.
jwcn
Sat Jan 26, 2008 6:20 pm
or RSTP
Users browsing this forum: No registered users and 24 guests
