MUM Europe 2020
omar_1966
POOR LINK PERFORMANCE
Sat Feb 09, 2008 9:08 pm
HI
WHAT IS A GOOD SINGAL TO NOISE READING, AND TX/RX CCQ.
I AM HAVING LARGE PINGS AND LOW BANDWIDTH AT DIFFERENT TIMES, THIS CAN LAST FROM MINUTES TO HOURS AND THAN STAY WORKING FINE FOR ONE OR TWO DAYS WITHOUT ANY TROUBLE.
PLEASE HELP
THANK YOU
DesertTek
Re: POOR LINK PERFORMANCE
Sun Feb 10, 2008 11:26 am
We typically aim for a SNR of 25 or better, a CCQ (fluctuations accounted for) of not less than 70%, and a radio signal strength of -79 or lower. Any worse than this we consider a stronger card, different antenna, elevated mount, etc.
BTW, my installers have to be constantly reminded to create a clear fresnel zone. This is a VERY common oversight. Read more here:
http://en.wikipedia.org/wiki/Fresnel_zone
omar_1966
Sun Feb 10, 2008 9:34 pm
THANKS FOR ANSWERING
I HAVE THE S.N.R READIN NOT GRAETER THEN 25 IN 90% OF MY CLIENTS, I HAVE SEEN S.N.R READINGS FROM -3 TO 26.
I HAVE A CLIENT ABOUT 600 METERS WITH A PERFECT L.OS. AND SIGNAL BETWEEN 50S
AND STILL HAVE THE LOW PERFORMANCE AT THE SAME TIME THAT THE OTHERS HAVE.
ALL POINTS WORK FINE FOR HOURS AND THEN FOR MINUTES OR 1 OR 2 HOURS THE LONG PINGS AND LOW BANDWIDTH TIME APPEARS.
I HAVE RB133 AND UBOQUITY XR2 RADIO END A 16DB 120º SECTORIAL.
DO YOU HAVE ANY MORE IDEAS?
THANK YOU
wildbill442
Mon Feb 11, 2008 10:07 pm
sounds like noise (in-band), if it's intermittent, and is across the board (all clients seeing high pings low throughput).
Try a different channel, or a channel filter.
William Burnett
Network Engineer
omar_1966
Tue Feb 12, 2008 8:31 am
I HAVE A HYPERLINK FIXED CHANNEL BANDPASS FILTER I ONLY USED A FEW HOURS BECAUSE SIGNALS DROPED VERY MUCH, ABOUT 20% I HAVE A ONE WATT AMP THAT I AM NOT USING. DO YOU THINK I SHOULD TRY IT WITH THE AMP OR SEE WHAT HAPPENS IF I HAVE LOW SIGNALS??
YHANK YOU
nickb
Thu Feb 28, 2008 10:53 pm
First off - please find your caps lock next to the A button and press it.
I have seen this kind of symptoms before. Sometimes switching to B-only mode will fix it. In one case, we had the same behavior and had to replace the XR2 with an R52H to solve the problem.
Do not - repeat - DO NOT - use the amplifier. NO.
0ldman
Fri Feb 29, 2008 9:16 am
A couple of weak links can slow down the AP for everyone else. What is you worst customer's SNR?
Tanker
Fri Feb 29, 2008 10:34 am
Throw out the AMP.....!!!
.... and start again by re-configing - or at the very least checking EVERY config...
Amps should be forbidden ..!!
Just my .02c worth
T
Users browsing this forum: No registered users and 31 guests
