Jrslick22
Breaking 10-12Mbps on point to point links
Tue Feb 26, 2008 1:40 am
I have a RB333 with a point to point link to a RB133c i get -65dbm signal, 38db Sig to noise, link reports 36/36Mbps. When i do a bandwidth test on this and any of my other p2p links i can never seem to get over about 10-12Mbps tcp. other links include RB533 to RB333, RB533 to RB533s
Id love to get some of the speeds i read about in the forums. what other info do you want? what am i doing wrong?
thanks
tjohnson
Re: Breaking 10-12Mbps on point to point links
Tue Feb 26, 2008 4:52 am
How large of a channel are you using? 20mhz? 10mhz?
A rough breakdown with your hardware:
10mhz channel is going to provide about 15Mbps maximum (one direction at a time)
20mhz channel is going to provide about 28Mbps maximum (one direction at a time)
Also, are you using Nstreme? On point to point links it is always better to use Nstreme (in all the testing I have done with over 40 current links, up to 73 miles).
Travis
Jrslick22
Tue Feb 26, 2008 5:50 am
Ok that makes a lot of sense, how do i make the channels 20mhz? i only see 5 and 10mhz, yes i'm using Nstream, will test it and let you know.
tjohnson
Tue Feb 26, 2008 6:24 am
The default "5ghz" setting is 20mhz wide... "5ghz-turbo" is 40mhz wide.
Travis
Travis
Jrslick22
Tue Feb 26, 2008 7:18 am
Travis
In 5ghz i only have %ghz, 5ghz 10mhz, 5ghz 5mhz. its an R52h, would country code restrict this?
regards
Alex
Tue Feb 26, 2008 8:44 am
for me pair of 133c with 2.9.50 have 2,2 MB/s real troughputpair of 532a have about 4 MB/s real troughput.it is simple wds bridges.
do you use nstream on 133c? it have slow cpu.for high speed ptp links you need:
1) power boards like 333 or 600 or PC router with fast cpu.
2) stable signal
3) well configured system
4)5-turbo if it is allowed in your country
Disable all you dont need, uninstall all unneeded packages.For example, on 133c I have installed only system, wireless and routerboard packages.
0ldman
Tue Feb 26, 2008 8:57 am
If you just need a WDS p2p, the 411 has impressed me. At 5GHz turbo, I've gotten around 20mbps in one way, 17 and 12 in bandwidth tests both directions. I need time to test more thoroughly.
Alex
Tue Feb 26, 2008 12:25 pm
i have tested 411 too as wds bridges.At table with ROS 3.3 i`ve got stable 3 MB/s (24 mbps) with 5Ghz and around 5 Mb/s(40 bmps) one way with nstreme enabled.
nowires
Tue Feb 26, 2008 4:48 pm
Good numbers :D
But are they with TCP or UDP? Can you try with both directions?
Alex
Tue Feb 26, 2008 10:26 pm
scenario of test was pc1--411~~~411-pc2.pc1 had freebsd+proftpd,pc2 was notebook with xp and total commander.
Jrslick22
Wed Feb 27, 2008 10:23 pm
Good numbers :D
yep real nice numbers
Users browsing this forum: beckerf, guntiss and 59 guests
