datawlan
RB600 is killing Prism 200nW (2511) cards
Fri Feb 29, 2008 11:28 pm
Hello Everyone!
We have this sad experience, that Our RB600 (with the RB604 extension) is killink Our Prism 2511 cards. This is the "only" card which is suitable under omni antenna, and works in stormy environment (lighting and noise kills other cards, but this).
Any experience with this configuration? Tomorrow we will exchange this Prism 2511 to a R52, and we hope that it works. If not working, we must install a RB411 separately and connect to RB600 vie ethernet.
Many thanks for replies
WBR
Zsolt
+36202942949
Equis
Forum Veteran
Forum Veteran
Re: RB600 is killing Prism 200nW (2511) cards
Sun Mar 02, 2008 2:38 am
you can use xr2
other option is to run wire from tip of omni to the ground
ericsooter
Sun Mar 02, 2008 4:05 am
In my experience, Atheros cards w/omni seem to be susceptible to static discharge. Make sure you have a good ground running to the base of the tower. Also, make sure that the coax running from the omni to the radio has a ground kit on it (very important). And even better, make sure there is a lightning arrestor in the mix. With this grounding scenario, I haven't lost a single R52, CM9, or other atheros based card to static. And they tend to perform better in high static weather conditions. I am in a very weather ridden area (thunderstorms and high wind), so this is very important to us. Although, the prism cards don't seem as affected be static, they will also perform a little better with properly grounded coax. And of course, the XR2/5 card has spectacular static protection built onto the card (as long as you properly ground the card). Also, not sure if you are amping the prism, but you will need to remove it when using an atheros card (amp+atheros=crap). I've always noticed that a good atheros based tower will outperform a prism based one as the number of users goes up.
datawlan
Sun Mar 02, 2008 8:14 am
Hello!
Thanks for the replies.
The fact is, that the prism 2511 was working for 1,5 years in RB532.
Now, that the new RB600 came out, we have decided to replace. After replacement, the Prism was OK for 1 week. We put a new one in, which was also prefect for about 1 week.
Now the R52 is in, works well, we will see the result after a week or two.
That was strange for me, that the prism goes wrong in RB600.
Rds
Zsolt
uldis
Mon Mar 03, 2008 5:09 pm
what symptoms has the RB600 when it is running Prism card?
Does it reboots, looses clients or stops forwaring traffic to prism clients?
busa1300
Tue Mar 04, 2008 10:59 pm
Our experience has been a rb333 has stopped fowarding traffic with the prism card (2511), have not taken tower down lately to check os3.3
datawlan
Wed Mar 05, 2008 7:25 am
goes blind: does not see anything, and as AP it is unseen by clients
keletiferi
Thu Mar 06, 2008 2:44 pm
Problem is similar. I think problem with 3.0
Not have a traffic on prism card, and if have more clients,
ap is drop clients.
Alessio Garavano
Fri Jun 06, 2008 4:41 pm
Try with v3.2... ;)
Look here:
http://forum.mikrotik.com/viewtopic.php ... 50#p117950
Regards,
Alessio Garavano
http://www.isparg.com.ar
Users browsing this forum: jebz and 12 guests
