MUM Europe 2020
HellMind
Optimize p-t-p rb133 transparent link
Thu Apr 10, 2008 10:31 am
How can avoid using the 100% of the cpu?
I got 2 rb 133 with 2 r52
3.7 router os
Station -> bridge
wpa2 enable
the bandwidth tool is 20 mb udp, (but i think the bottle neck is the cpu),
The 5ghz and 5ghz turbo mode shows the same performance
I disable connection tracking but i didnt see any difference
Thank you
Alex
Re: Optimize p-t-p rb133 transparent link
Thu Apr 10, 2008 12:44 pm
uninstall all unneeded packages
HellMind
Sat Apr 12, 2008 10:02 am
What for?
if the packages aren't being used then the cpu load can't be affected
valypetre
Sat Apr 12, 2008 2:04 pm
disable encryption
ovkiller
Mon Apr 14, 2008 4:30 pm
had the same problem and reached only 600kb/s :)
CPU was 100%
u know how i solved it??? bought 2 x RB333 :). its expencive but it works great and it worth the money. THANKS MIKROTIK :)
magic
Tue Apr 15, 2008 9:28 am
Use RB333 if you need more bandwidth.
Krisztian Gancs
RLAN Internet Ltd.
http://www.rlan.hu
HellMind
Wed Apr 16, 2008 4:30 am
disable encryption
No, the r52 do all the encryption stuff by hardware, so its the same
I tried with encryption , without it, and with compression too.
bedris
Wed Apr 16, 2008 9:07 am
HellMind
On RB133 better use ROS 2.9x
HellMind
Sat Apr 19, 2008 4:29 am
With 2.9 i got the same benchmark result
Maybe the cpu is the bottle neck
Users browsing this forum: macsrwe and 28 guests
