RK
Long time Member
Long time Member
Tower and Mast Options
Fri Apr 11, 2008 12:01 pm
I want to place a few antennas on a hill that is about 1200 feet (365 meters) asl/agl.
I'd like to place the antennas (mostly panels) about 7' to 15' above ground.
Do you build/weld your own towers, or is there a good manufacturer out there that someone here can recommend?
Or maybe I can get away with an aluminum pipe serving as a mast?
jordantrx
Long time Member
Long time Member
Re: Tower and Mast Options
Fri Apr 11, 2008 3:31 pm
If your looking for Towers Look up titan towers on google, Thats what i will be using for towers.. but for only 15 feet... I guess a pipe should work alright. http://www.rflinx.com/products/transmission-towers/ good luck. -jordan
~Agricultural WISP "ZONE"~ Beware of oncoming cattle and dont hit the farmer!!! I need to ask him about using his silo for an AP first"~
*Automated Billing Installer* http://wiki.mikrotik.com/wiki/AutomatedBilling Built by Krige ;-)
RK
Long time Member
Long time Member
Sat Apr 12, 2008 2:12 pm
Anyone has another favorite tower brand?
tgrand
Long time Member
Long time Member
Sat Apr 12, 2008 2:50 pm
for 7 to 15 feet just use galvanized pipe.
Or perhaps a pop-up mast.
Where in canada are you, as I may be able to recommend suppliers.
RK
Long time Member
Long time Member
Sat Apr 12, 2008 6:09 pm
This project is in Panama (central america).
off topic:
However, we do run a (W)ISP in Winnipeg (downtown). The only MikroTik user I know of in the area (besides us) is HSC.
tgrand, email me please, rk @ rontec.net, I'd like to talk about peering and trading roof/tower space.
snowpro
Sun Apr 13, 2008 1:03 am
you mean dealer in Panama?
or Canada http://www.xagyl.com
RK
Long time Member
Long time Member
Sun Apr 13, 2008 7:10 am
I'm not looking for a dealer. I'm looking for recommendations for specific products.
Getting the stuff delivered is the easy part - there are plenty of mail forwarding services.
Users browsing this forum: MSN [Bot] and 35 guests
