MUM Europe 2020
heinb
Daughterboard not running on AP
Sat May 03, 2008 6:24 pm
Hi
I've checked the forums, but I couldn't find a similar post.
I'm experiencing the following problem on our AP setup - We have a RB532 with an extra daughterboard (can't recall the model nr now). Regardless, this daughterboard (channel 2) on our AP, stops running.
Despite disabling and re-enabling it, it receives packets for a few seconds and then stops again. Up the yesterday, it was still working fine.
Any ideas?
jwcn
Re: Daughterboard not running on AP
Sun May 04, 2008 2:12 am
are you talking about a daughterboard or a wireless radio?
heinb
Sun May 04, 2008 10:07 am
I'm guessing it's the wireless radio.
jwcn
Sun May 04, 2008 4:08 pm
Sounds like a bad card.
heinb
Sun May 04, 2008 4:57 pm
After I've rebooted the AP, the radio runs again? I'll take it as a bad card.
jwcn
Sun May 04, 2008 5:53 pm
Without knowing your exact configuration both hardware and software it is impossible to form an educated opinion as to what is wrong.
Tanker
Wed May 07, 2008 4:46 pm
I'm going to take a wild guess here....
Try unplugging the RB504 daughterboard and carefully re-inserting it onto the RB532....
We've had a couple of these where the pins don't seat properly.
Just our experiance.. painful as it may be (the board might be way up a tower) - bring it down to where you can work properly and try it...
It could be a bad card - but I've rarely seen a card absolutely DOA.
T
jwcn
Wed May 07, 2008 5:17 pm
I think it was established there is no daughterboard. The OP was confusing daughterboard with wireless card
heinb
Fri May 09, 2008 4:29 pm
Hi Tanker
There is a daughterboard (most likely RB504) hosted with the RB532 routerboard. Just some feedback: The daughterboard sporadically stops running. On rebooting the AP, it starts running again.
It's either not seated properly (as you indicated); or it could be a faulty card, as we have a second AP with exactly the same setup - but the problem as ascribed has never occured on that particular AP.
jwcn
Fri May 09, 2008 5:25 pm
Could be moisture too...
Tanker
Sun May 11, 2008 4:30 pm
Yo Hein
Have you checked the power supply to that setup???
What radio cards are plugged into the daughterboard???
Contact me operations[at]radioactivewifi.co.za with your tel number - I'll call you
We have 50+ of these running in our network and it could be a pile of things that could be bugging that board.
But - it's (normally) easy to sort out.
Let me know
Tanker
Users browsing this forum: MSN [Bot] and 16 guests
