ericsooter
Adaptive Noise Immunity
Wed May 07, 2008 9:52 pm
Is there a benefit to this setting? I noticed some posts regarding how turning on Noise Immunity causes CPU usage to go
high. Going by the name, ANI seems like a good thing. Anyone have any thoughts on this?
Eric
jwcn
Re: Adaptive Noise Immunity
Thu May 08, 2008 3:26 am
I noticed an immediate benefit in throughput. I have it running on a 532 with WLM54G Compex card a 532 with SR2 and a 112 with SR2 all working flawlessly.
ericsooter
Thu May 08, 2008 5:06 pm
Sounds great. I just saw this post in the routerboard forum and it concerned me. Are we going to have ultra-high cpu loads from doing this? Here are clips of that thread:
QPox:
I'm running RouterOS 3.7 on a Routerboard 333 with 3x R52.
And my CPU load jump from 70% to 100% (about an average of 50% on graph)
I've try'd to reboot alot of times, but it just jumps to a 100% again after it reboots.
But when i disable wlan2 i falls for a bit, then after some time it's a 80% again.
And there is no trafic!
uldis:
please set the wireless cards setting 'adaptive-noise-immunity' to 'no'
QPox:
Yes that did the trick!
Thank you!!!
jwcn
Fri May 09, 2008 9:33 am
I believe this is an isolated problem with the R52 cards...
normis
Fri May 09, 2008 10:38 am
No, this depends on two things - CPU power and Noise in your area. If there is a lot of noise, the ANI will work harder, and will hit on low-speed device resources. For fast RouterBOARDs this will not be an issue.
jwcn
Fri May 09, 2008 5:20 pm
Makes sense. Thanks for the clarification.
jose
Thu May 15, 2008 2:21 am
In v.3.9 In the "Adaptive Noise Immunity" I see the following fields
-AP and client mode
-client mode
What is the difference between them?
thavinci
Wed May 21, 2008 12:12 pm
*bump*
http://www.thavinci.za.net
echo "Demo license expired!"
echo "Please reinstall the router."
echo
kill -WINCH 1
exit
Eliminateur
Thu May 29, 2008 1:36 pm
*bump for the last question*
uldis
Thu May 29, 2008 2:02 pm
- none - disabled,
- client-mode - ANI will be enabled only if the interface mode will be station or station-wds,
- ap-and-client-mode - ANI will be enabled on all the interface modes
Equis
Forum Veteran
Forum Veteran
Fri May 30, 2008 2:52 am
What cards does ANI work with ?
r52? cm9? xr2?
Anyone think this works well?
How does it work?
jwcn
Fri May 30, 2008 7:25 am
Works with Atheros based radios.
techmonkey1
Mon Jun 02, 2008 5:39 pm
Will ANI work in a Hotspot senario with laptop clients?
hulk-bd
Thu Jun 05, 2008 10:56 pm
Is this option is only in Ver 3.x?
Don't worry, be happy :) .......
jwcn
Fri Jun 06, 2008 2:34 am
Yes
tjohnson
Thu Jun 26, 2008 4:53 am
Does this need to be enabled on the AP and client side to be effective? If we are running station-psuedobridge on the client side, I assume we would have to use the "AP and client mode" setting, correct?
Travis
thavinci
Mon Apr 27, 2009 10:57 am
Yes it does need too be enabled both sides too be affective....
Station-psuedobridge, will probably need client mode, however i just make a habit of enabling "AP And client mode", thus accommodating for both cases.
I have found that this makes a HUGE difference in noisy areas, but yes you're CPU Usage is directly related to how noisy you're area is and how many clients you have.
ie
This is a 3.2Ghz PC and look at the CPU Usage, this is all due too the noise in that area!
So you will have to investigate if you're routerboard has the beef too cope with the noise in that area if it is noisy!
my 2p
echo
kill -WINCH 1
exit
Users browsing this forum: Baidu [Spider], bpwl, WAVEBANDJoe and 18 guests
