Hi Guys
With a 5 mile link -60 at each end running an rb333, what speed would you expect to get?
would 20Mbps be about right?
Does anybody know why the 10mhz and 20mhz spectrum gives less bandwidth? Where standard 802.11a with standard channels gives a faster connection? Just curious. -JordanI've got a 6.6 mile shot, 5GHz, 10MHz channel, I get about 10Mbps. Signal is -68 to -75.
Using standard channel bandwidth, yea, you can get 20Mbps.
I get the same results as you equis. However I do notice even with the good signal Bandwidth is degraded compared to the regular frequency. -JordanOK, Thank for the reply.
I am not so smart in this area, do you knwo why 5mhz seems to give a better signal than 10mhz etc?
eg
a sample could be
20mhz -70
10mhz - 67
5mhz -64
