unlimitedme
Multiple VLAN ID over wireless link, possible?
Sat Jul 12, 2008 7:43 am
Dear all,
i have been trying to create a multiple VLAN connection over an existing wireless link, but every time i create a VLAN, and add the existing WLAN interface to VLAN, then the wireless connection will be broken, and disconnect.
The reason i do this, because i have multiple router behind the wireless link, and i need to separate each of them via a VLAN.
Please help, what method did i miss? or is this an incorrect setting?
I am using ROS 3.11.
Thanks a lot for your reply
QpoX
Re: Multiple VLAN ID over wireless link, possible?
Sun Jul 13, 2008 2:38 pm
I think you need to use the WDS function...
QpoX
Sun Jul 13, 2008 2:47 pm
unlimitedme
Sun Jul 13, 2008 4:18 pm
QpoX,
Thank you for your reply, i have read those thread before.
but those thread use multiple interface wlan.
My situation is like this:
[Router A]**via LAN cable**[Client]~~~via wireless~~~[AP]**Via Lan cable**[Router B]
on Router A: 2 ether
on Client (routerboard) : 1 ether, 1 wlan
on AP (routerboard): 1 ether, 1 wlan
on Router B: 2 ether
The target is to create a vlan from network behind client to the other side of AP.
I just give example with router A and router B, in reality i have multiple router behind the client.
I have try to create vlan between router [A] and [Client], but since only 1 interface wlan,
i dont know how to create multiple vlan for another router behind [Client]
Do i make you dizzy?
Please help...do you have any direction?
Thank you so much for your kind reply
unlimitedme
Wed Jul 16, 2008 8:08 am
please help anyone?
hytanium
Sun Jul 20, 2008 7:15 am
You must use wds bridging. Create your vlans on wlan interface
Create a bridge for each vlan, in ports add vlan to appropriate bridge. We use wds bridging network wide... works very well.
unlimitedme
Sun Jul 20, 2008 2:32 pm
hytanium,
Thank you so much for your reply...
I am not quite sure about the wds bridging.
What do i need to use as default bridging in the wlan for each network ?
Because there is only 1 wlan on the each side of the radio.
[Router A,B,C]**via LAN cable**[Client]~~~via wireless~~~[AP]**Via Lan cable**[Router D,E,F]
For network A:
wlan1 : default bridge: Bridge A
Bridge A, port = vlan_A_wlan1, ether 1
For network B:
wlan1 : default bridge: ???
Bridge B, port = vlan_B_wlan1, ether 1
For network C:
Bridge C, port = vlan_C_wlan1, ether 1
Please help me..
meno
Sun Jul 20, 2008 9:13 pm
any ideas how to make a VTP (trunk mode) on a P2P wireless conection ???
LAN----- switch on Trunk port -----wireless()))))))(((((((((( wireless ---------switch on trunk port ---- LAN
unlimitedme
Mon Jul 21, 2008 12:00 pm
meno,
i think your case is similar with my case.
can you tell me, how many progress that you made?
i have try the following:
on client radio:
bridge port : vlan from ether , vlan from wlan
on router A behind client radio:
bridge port : vlan from ether1, ether 2
but the connection between client radio with AP, always failed to conect.
somebody have this same case?
unlimitedme
Mon Jul 21, 2008 12:15 pm
Normis/Janis/Everyone,
Please help...
I have try to draw my scenario, please give me advice.
I am using RouterOS 3.11 on both radio clients and Access Point radio
Please advice, any reply will be highly appreciated
Thank you
note:
i updated the picture, to clearly explain the issue
we need to create separate vlan id between clients
wpeople
Mon Jul 21, 2008 10:16 pm
If i'm right, you have 3 clients connecting to AP.
VLAN1 is connecting to all 3 clients AND AP, but VLAN2 only to eth2 of clients.
For this, you have to make an AP, with WDS allowed.
-all clients will have it's own WDS interface (like wds-client1 or so)
-make VLAN1 interface bound to all wds-clientX interface (like vlan1-client1)
-put all the vlan1-clientX interface to bridge (if needed)
-make VLAN2 interface bound to all wds-clientX interface (like vlan2-client1)
-put all the vlan2-clientX interface to bridge (if needed)
On clients:
make station-wds interface
make VLAN1 interface bound to station-wds (bridge it with ether1)
make VLAN2 interface bound to station-wds (bridge it with ether2)
Keep in mind, if you want to use VLAN interfaces, don't use their master (physical) interface!
unlimitedme
Wed Jul 23, 2008 9:33 am
wpeople,
how to create multiple wds for each client?
please take a look at my updated picture.
thanks a lot for your kind reply
jorj
Thu Jul 24, 2008 11:58 pm
I don't really get the point of your separation in vlans, but you might use EOIP tunnels, between the client routers and the router in the right of your picture, and run them across any routed network in between, and in this way you have a "virtual ethernet" to your clients, passing layer 2 data.
After this, use your imagination.
:D
onnoossendrijver
Fri Jul 25, 2008 12:34 am
I currently use 4 EoIP tunnels and bridge them to a VLAN. Works very nice!
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
Diganet
Sat Jul 26, 2008 2:09 am
Please help...
Thank you
note:
You have to start with putting in a managed, VLAN capable switch to allow for VLANs to get through.
Regards
Henrik
wpeople
Sat Jul 26, 2008 1:49 pm
Well, EoIP should work, but its using extra resources, while VLAN is a simple bridge, with (i think) minimal extra resouce to put extra 22byte on the frames.
unlimitedme: you need only one WDS on each client, but need more VLAN
you need this on AP side:
add arp=enabled comment="" disabled=no interface=xxx-wds mtu=1500 \
name="backbone_vlan_xxx" vlan-id=1000
name="bridge_xxx" vlan-id=1
you need this on CPE side:
add arp=enabled comment="" disabled=no interface=wlan1 mtu=1500 \
than bridge the backbone_vlan_xxx interface with eth1 and bridge_xxx with eth2
oh, the above for passing VLAN over wireless.
if didn't realised - until now - that you want to pass VLAN on wire.
For this you must have an active node (let's say 802.1q capable switch) to work well - or have a mikrotik CPE with 3 ethernet ports
connecting client1 to eth1 and so.
jorj
Sun Jul 27, 2008 8:26 pm
I participated in that topic, being worried about the eoip overhead. In my scenario, it prooved of little impact. I am transferring about 10 mbits over 2 hops, wireless, with just about no impact in performance, as far as i can see it.
unlimitedme
Thu Jul 31, 2008 6:58 am
jorj,
I will try to use EOIP then, i will let you know the result.
onnoossendrijver,
Interesting, i will see if we can bridge EOIP with a VLAN.
Diganet,
Why use managable swith, if we can elaborate it with MikroTik?
wpeople,
we have minimal ethernet port resource on the AP and the client, so i am looking a way to outcome this situation.
cybernet
Wed Aug 06, 2008 2:49 pm
you can try this configuration:
Radio AP:
on interface:
- create bridge1
on wireless:
- Radio Mode bridge or ap-bridge
- WDS mode dynamic
- WDS default bridge bridge1
on bridge :
Add port ether1-->bridge1
Add port wlan1--> bridge1
Radio Client:
on interface :
- create bridge1
on wireless
- Radio Mode station-wds
- WDS mode dynamic
on bridge :
- Add port ether1-->bridge1
- Add port wlan1--> bridge1
hope work with your network.
sorry i not familiar with CLI. just using GUI.
unlimitedme
Thu Aug 07, 2008 7:13 am
cybernet,
What you said is just an ordinary way to bridge two network over wireless, and that was not my question.
Thanks anyway for your post.
cybernet
Fri Aug 08, 2008 5:39 am
a lot of unmanaged switches do not support 802.1q tags, so you'll have to treat it like an access port.
unlimitedme
Fri Aug 08, 2008 5:55 am
cybernet,
Thank you for your post, yes i am using unmanageable switch, so i want to overcome this situation.
I do not understand about your post,
If you have same situation, maybe you can post what you have accomplish.
For now, we are using EOIP.
Do you have other solution?
Thank you
sudiptakp
Sun Jan 24, 2010 8:30 am
http://wiki.mikrotik.com/wiki/802.1q_Tr ... s_P2P_Link
This is all you require.
Thanks,
Sudipta
cmanciu
Sat Jun 06, 2015 6:50 pm
mr. sudiptakp
i've used that link b4, and i still couldn't get it to work....i know this is a old post reply.....but what else is needed to make it work...im using rb433uah i believe it is
Users browsing this forum: No registered users and 80 guests
