yri
Wireless clients Shaping
Fri Jul 25, 2008 11:00 am
Is there a solution to shape traffic between wifi clients connected to AP
1 - shape speed in access list
2 - route? how? didn't work
3 - any ideas?
sergejs
Re: Wireless clients Shaping
Fri Jul 25, 2008 3:15 pm
Access-list is working only between MikroTik Routers.
But you can use regular queues to apply bandwidth shaping,
http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php
mvn77
Sun Jul 27, 2008 10:14 am
Help!!! It is Necessary see example/ :(
jwcn
Mon Jul 28, 2008 12:20 am
There are examples in the manual and wiki
mvn77
Mon Jul 28, 2008 7:32 am
tried all, not to shape traffic between wifi clients connected to AP. Help. Needs worker an example
yri
Mon Jul 28, 2008 10:41 am
Cant you read? its BETWEEN AP CLIENTS
and needet to be shaped Between wifi clients connected to mikrotik
natedogg104
Tue Jul 29, 2008 1:03 am
So if you wanted to shape the bandwidth between the clients on a wifi network connected to a particular ap, they you would bind the cleints mac address to an ip address and then use the http://www.mikrotik.com/testdocs/ros/3.0/qos/queue.php to in order to shape the bandwidth between the clients, now if the clients talk to each other without useing the gateway of the routeros, then the clients would need thier own shaping done on the client side, which can be done easily on every wifi client that is running routeros , but true laptop accounts that just use the wifi card in the laptop would be unaffected
mvn77
Thu Jul 31, 2008 8:40 am
Sorry for misunderstanding. IT is not possible to limit traffic between
wireless clients with mangle and queues, because Router is not seeing traffic
between clients.
Only solution to limit this kind of traffic is to set default-ap-tx-limit in
wireless interface settings or set ap-tx-limit to wireless access list
entries.
Note that client-tx-limit will work only if wireless client is mikrotik device
too.
Regards,
Maris
Сan through routing possible?
Users browsing this forum: Google [Bot] and 38 guests
