MUM Europe 2020
dchouinard
VLAN Assignation per user using RADIUS
Tue Aug 12, 2008 6:42 pm
Greeting everyone.
I do WPA authentication using a RADIUS server (freeradius on a zeroshell server). On the server I can specify a the client assigned VLAN (802.1x).
I need my AP to assign dynamicly the vlan to the wireless client. This will allow differents clients to be on differents networks.
TRUNK PORT -> ETH2 -> WAP -> CLIENT on vlan 3404
\-> CLIENT2 on vlan 3410
I understand that I need to brigde my WAP and the ETH2 interface. But I do not understand where the packet is going to be tagged and how to tell routeros to do that.
I am yet to find documentation or information.
Any idea?
Dany Chouinard
meno
Re: VLAN Assignation per user using RADIUS
Wed Aug 13, 2008 3:14 am
That is kinda I want to make.. create a vlan per customer... but I dont know exactly how do that on wimax profesional equipment like alvarion,. I heared about a pseudo vlan.. but that all I know in 802.11a/b/g
dchouinard
Wed Aug 13, 2008 6:14 pm
I have found a good description of what I'm trying to accomplish. But I am yet to figure how to do it with routerOS.
http://searchsecurity.techtarget.com/ge ... 11,00.html
Belyivulk
Thu Aug 14, 2008 1:33 am
This sounds like something we would be interested in knowing about as well
cmit
Thu Aug 14, 2008 12:04 pm
As can be read in the post the key is that RouterOS has to understand those RADIUS attributes (and act accordingly).
I don't think this is implemented right now.
Best bet would be to write a feature request to support, I suppose...
Best regards,
Christian Meis
joefat
Thu Nov 04, 2010 3:47 pm
Did this ever get implemented?
Was there a feature request?
Currently I can only get this functionality with products like HP, Trapeze etc. If I could use the "Client Assigned VLAN" attribute in RouterOS then I'd be able to deploy a lot more MikroTik.
I only need the AP to respect the attribute in WPA2-EAP scenarios. Don't necessarily need it in HotSpot or UserManager.
Ta
fewi
Sat Nov 06, 2010 7:05 pm
It is not implemented in any current version.
joefat
Sun Nov 07, 2010 5:30 pm
Ok, would it be possible? How do I make a feature request? Can anyone think of a workaround?
Perhaps I'll look at the L2 firewall...
Ta
duvi
Sun Nov 07, 2010 8:02 pm
Maybe you could try openwrt, this feature is working with it.
joefat
Mon Nov 08, 2010 11:13 am
That's interesting, I didn't know that. I'll take a look.
The thing is that I already have a significant (city wide) Mikrotik deployment so I'd like to stick with that if possible.
Ta
joefat
Wed Nov 10, 2010 12:02 am
Duvi - I can't see this in any of the OpenWRT documentation and I've Googled pretty hard ...
Could you point me in the right direction please.
dssmiktik
Forum Veteran
Forum Veteran
Wed Nov 10, 2010 12:39 am
If you turn on radius debug logging, does that attribute show up in the logs? If it does, a workaround would be to write a script to monitor the radius log, watching for that attribute. Then you could take any action you wanted based on the entry in the log. It is a bit of a hack, but may get you going in the meantime, if required.
Doug
duvi
Wed Nov 10, 2010 12:55 am
It's described here http://rpc.one.pl/index.php/lista-artyk ... em-hostapd
It's in Polish, but it's not too hard to get the point from the config files.
dssmiktik
Forum Veteran
Forum Veteran
Wed Nov 10, 2010 2:19 am
Translated in English:
http://translate.google.com/translate?h ... pd&prev=_t
Doug
joefat
Wed Nov 10, 2010 9:28 am
That's an interesting idea Doug...
Perhaps I can script dynamic L2 NAT rules to forward the client's traffic to/from the right VLAN...
joefat
Wed Nov 10, 2010 10:44 am
Wow! It's a shame that we can't have access to wireless interfaces from MetaRouters :-(
Then I could use OpenWRT to do this on my existing MikroTik installations.
I've added "Support for RADIUS Subscriber Assigned VLAN attribute in 802.1x" to the MikroTik feature request Wiki...
I guess people can vote for it if they think it would be useful :-)
In the meantime I'll be learning OpenWRT then...
Matt
Users browsing this forum: Dinskuns, WN1X and 28 guests
