bledar
Wi-Fi Phone
Wed Sep 03, 2008 9:06 pm
Hello!
I want to create a wi-fi phone network wit omni mikrotik antena.
But I want to find any wi-fi phone with hi gain antena.
Can someone know one of these that works on about 0.5Km distance or more from base station?
Thank You for helping me!
Regards.
jp
Long time Member
Long time Member
Re: Wi-Fi Phone
Thu Sep 04, 2008 2:57 am
If it doesn't need to be mobile, you are probably best off using directional antennas, ethernet bridges, and wired ATAs or IP phones.
bledar
Re: Wi-Fi Phone
Fri Sep 05, 2008 12:06 pm
It must be wireless.
Have any one any idea?
Hi gain phone?
Thnx.
Regards.
QpoX
Re: Wi-Fi Phone
Fri Sep 05, 2008 9:42 pm
Wifi 802.11a/b/g is LoS (Line of Sight).
Not a great idea for phone use.
But the phones that are on the market today is usable up to 300meters outdoor LoS...
And to comment on http://forum.mikrotik.com/viewtopic.php?f=7&t=26390
if the phone unit can't send data back there is no point of using it...
But look at Zyxel and Linksys phones...
GuJack20
Trainer
Trainer
Re: Wi-Fi Phone
Sat Oct 11, 2008 11:07 pm
I don't think that you can do something like that with the 802.11. As QpoX explained the LOS is the biggest problem. You can achieve something with different omnis but for more than 500m you will need a very good coverage of the terrain, especially if it is full of buildings..
--Do you remember that guy who gave up? Neither does anybody else!
Tanker
Re: Wi-Fi Phone
Tue Oct 14, 2008 10:04 am
Good day,
I would like to throw my 02 cents in here....
Our network coverage is extensive in an area which is "communicationally challenged" (very little comms at all) - and after a lot of "client pressure" we ventured into VoIP and now have ± 100 numbers up and running from the client's premises off our own SIP server on Asterisk.
Because our HQ is based in a small community we have had lots of enqiries about VoIP mobile phone "lines" - ie: open some of the 2.4GHz BSS to allow for authenticated phone MACs to make calls.... which led to some "experimentation".
Be it as it may - we found that the new generation of GSM cell phones (Nokia E65 etc) have 100mw 2.4 GHz capability - and that lots of cell phone carriers were VERY interested n this....
We continue - with good success I might add... it works well and the cell phones register with the SIP server nicely and when "out of range" de-register.. so it actually makes things easy. Initially it impacted our call desk but seems to have settled in nicely now.
Hope this helps.
Tanker
bledar
Re: Wi-Fi Phone
Wed Oct 22, 2008 2:14 pm
Hello.
Thnx for your info and supporting me.
Please, phone with 100mW at 2.4 GHz capability at which distance from AP works?
What dbi gain must have access point for working at maximum distance that allowing TX of phone (Nokia E51, E65) ?
Regards.
bledar
Re: Wi-Fi Phone
Mon Nov 17, 2008 5:31 pm
Has any body any idea regarding this thread?
THNX.
Regards.
QpoX
Re: Wi-Fi Phone
Mon Nov 17, 2008 5:58 pm
Maybe this: http://www.solwise.co.uk/voip-phones-si680h.htm
The AccessPoint needs to be in LOS! and forget to use a Nokia phone! they only send out a few mW (as what i know of)...
But try to buy a AP and a Phone and do a test setup then change settings, antenna's and so on to improve your setup.
Tanker
Re: Wi-Fi Phone
Mon Nov 17, 2008 6:19 pm
yet again I'm confused - but - it doesn't take a lot....
I'm holding a Nokia E65
/menu tools/ settings/ wireless lan/ advanced settings/ and there is says Tx Power 100mW..
Like I said - it doesn't take a lot....
/T
QpoX
Re: Wi-Fi Phone
Mon Nov 17, 2008 7:39 pm
Cool... did not know that... (Not a big Nokia fan)... and did not see your post :)
bledar
Re: Wi-Fi Phone
Tue Nov 18, 2008 12:37 pm
Please, how meters about from AP goes 100mW phone covered?
Let say it will operate in full with building area.
Does it works about 80-100 meters from AP with that scenario?
Thank you for your help.
Regards.
QpoX
Re: Wi-Fi Phone
Tue Nov 18, 2008 1:29 pm
If you are lucky...
But it still depens on iron in the houses and so on...
I've had one where the AP was 2meters from a computer in another room and in the wall there was Aluminium foil (to keep heat in the rooms) there was no signal at all...
But if you are in LOS from the phone to the AP, a 100meters should be no problem...
The way to go around is really WDS and setup more AP's where there are holes...
bledar
Re: Wi-Fi Phone
Wed Nov 19, 2008 10:40 am
OK. Thank you QpoX for your continuous support.
Have a good day.
Regards.
Tanker
Re: Wi-Fi Phone
Fri Nov 28, 2008 10:49 am
We run a VoIP system for our customers (CPE's with VoIP phones) ...
We decided to try and energise all our "hotspots" in our town...
- (these are essentially 5 GHz incoming with 2.4 GHz Omnis for the client's PC's Laptops etc) -
- to allow users to "buy" a line for cell phones which had wireless installed. These users would then be authenticated on the "hotspots" and make calls as and when they were close to any of the Omnis....
Typically we see anything between 30 metres in and around buildings and up 120 metres in free air.
Either way the users who have subscribed to the service are happy - as an experiment it has worked well.
Of course - you will always get those who want to "push the boundries" - so if this is not enough - or the phone will not make it - ??? - we'll have to wait for phones with R52H's built-in.... :)
We have also installed Indoor AP's with 7 dBi Whip antennas for customers and these deliver 30 metres easily.
Just our experiances is all....
T
Users browsing this forum: MSN [Bot] and 36 guests
