laxmi
How to reduce noise levels on long distance links
Thu Sep 11, 2008 6:24 am
Hello Everybody.
We are having long distance links in our network. Is there any way that we can reduce the nosie levels. If so please suggest me a good solution.
normis
Re: How to reduce noise levels on long distance links
Thu Sep 11, 2008 1:07 pm
why do you think there is noise? what exactly is the problem with the link anyway?
expunge
Thu Sep 11, 2008 6:52 pm
There are only three real ways to reduce noise, no matter the link distance.
1) Change Frequencies
2) Use a more directional antenna
3) Stay at the current frequency and install a bandpass filter
As long as your setup is correctly installed, the only place you should get noise is from your surroundings. Thus, either change the surroundings (frequency), change the area of the surroundings you pickup up (antenna radiation pattern), or cut down the surrounding noise (filter).
You may also get some noise over very long links from random events but nothing will take care of that for you.
viceft
Thu Sep 25, 2008 5:46 am
You need connect to ground the radio and antena.
Regards.
laxmi
Tue Sep 30, 2008 9:10 am
The tower to which the attenea is connected is ground. Is that okay or a speical ground cable should be connected to attennea to reduce the noise levels
GuJack20
Trainer
Trainer
Tue Sep 30, 2008 12:49 pm
I don't think grounding has something to do with the noise levels..
--Do you remember that guy who gave up? Neither does anybody else!
nickb
Wed Oct 01, 2008 12:17 am
You wouldn't think so, but it does. I don't understand why, but it does.
roadrunner
Fri Oct 03, 2008 11:35 pm
Use better antennas, more narrow beamwidth, greater front to back ratio & greater cross-polarization rejection ratio.
On my longer links in noisy environments, I have had success using more narrow channels (5 or 10Mhz instead of 20Mhz). It does lower the bandwidth but the lower packet loss often makes up for it and runs quicker.
Users browsing this forum: No registered users and 18 guests
