el berto
RB411 on my own access point: how do it?
Tue Nov 04, 2008 5:26 pm
Hi, I hope to post in the right place!
I've been using RB411: one as access point (ap bridge), the others as "end point" (WDS station).
Now I want use a RB411 with my D-LINK access point I have at home.
I tried as "WDS station" mode, and it doesn't work.
I tried all modes, finally in "station" mode I see the radio running (connected to ESS).
I can see data excanged in graphic, but I can't ping and I can't go on internet.
Maybe I'm using a wrong wireless configuration.
May someone give me an hand?
Which configuratione are you using?
Thanks.
cinemadude
Re: RB411 on my own access point: how do it?
Thu Nov 13, 2008 10:23 pm
I would love to know too because that's also what I'm trying to do
I'm trying to run a rb411a as a 5.8 turbo 802.11A access point and with the ethernet port connected to a linksys router AP who also control the internet
the 411a can give DHCP address to the 802.11A laptops from the DHCP address bank on its own set of network address it could gets its own address under DHCP reservation from the linksys
all the laptops can ping each others , the 411a and the linksys
but no one can have access to the internet or others computer connected 802.11b/g or ethernet on the Linksys
someone told me it could be related to the NAT
also the wireless port could be setup under AP bridge station etc
could it be related to a wrong settting ?
csickles
Sat Nov 15, 2008 2:19 am
SRC NAT...
You need to create a SRCNAT on your router for the network "behind" the routerboard.
also make sure the network "behind" the routerboard can be routed / nated to the dlink network..
IE if the dlink issues a 192.XXX.XXX.XXX address then use a 10.XXX.XXX.XXX on the routerboard.
(Makes folowing the network easyer)..
something like SRC=10.0.0.0/16 dst 0.0.0.0/0 action SRCNAT..
Things that make you go "Hmmmmmmmm"...
Craig
csickles
Sun Nov 16, 2008 8:01 am
anothe option (and prob prefered...)
Action = Masquerade
Craig
Users browsing this forum: No registered users and 33 guests
