tjohnson
Scan list
Wed Nov 19, 2008 4:39 pm
We are having a problem when we change the country code to "ireland", and thus enabling 98 channels (using 5ghz-10mhz). If we leave the default scan-list (blank) we can not connect to anything higher than 5705. Yet if we set the scan-list on the client to include 5830 for example, the radio connects perfectly.
Also, if we set the AP to 5830 and set the client back to "none set" on the country code, it will connect perfectly as well. It almost seems like the client won't scan more than 75 channels.
Any ideas?
Travis
uldis
Re: Scan list
Tue Nov 25, 2008 4:34 pm
will be fixed in the next release of the RouterOS.
roadrunner
Re: Scan list
Fri Jan 09, 2009 10:48 pm
Any ideas?
Have you tried a scan-list to limit the number of channel choices? eg: 5495-5865?
roadrunner
Re: Scan list
Fri Jan 09, 2009 10:49 pm
Which release? v3.19 or v4Beta2?
tjohnson
Re: Scan list
Fri Jan 09, 2009 11:22 pm
This problem was fixed in v3.17. It has been working perfectly for us since then.
Travis
SNWiFi
Re: Scan list
Mon Oct 25, 2010 6:47 pm
How many freq could to put on scan list box ??'
Diego.
Users browsing this forum: No registered users and 18 guests
