jsuter
five R52's on one routerboard?
Thu Nov 20, 2008 5:12 am
I was wondering the maximum density you can achieve using R52 and R52H cards (or any suggestions on 'cleaner' cards for 11a use) at 5 ghz. I'm looking to install 5 5ghz links out of the one RB600-based box, 1x40mhz/nstream PTP, 1x20mhz/nstream PTP, 3x20mhz standard sectoral.
Thanks!
bellis
Re: five R52's on one routerboard?
Thu Nov 20, 2008 9:45 am
i would highly advise not to use rb600 for that much load. have been testing a pair of them in our network and they are continuously locking up on us, cpu is constantly maxed. you will be much better off using 2 rb433ah instead.
"If it ain't broke, you're not tryin"
0ldman
Fri Nov 21, 2008 5:20 am
I'm interested as well.
I've got 3 RB600's, had issues with one rebooting, works fine after a /system routerboard upgrade
Users browsing this forum: No registered users and 26 guests
