MUM Europe 2020
hgb
Rootenna for RB411
Sun Dec 07, 2008 4:45 pm
This one : http://www.microcom.us/wlana0044.html
And those : http://www.streakwave.com/Itemdesc.asp? ... 01&eq=&Tp=
http://www.streakwave.com/Itemdesc.asp? ... 02&eq=&Tp=
Which is best if there is any one tested them ... also any other alternative for client CPE "enclosure + antenna" they must fit RB411 .
thanks ...
jwcn
Re: Rootenna for RB411
Sun Dec 07, 2008 5:18 pm
I've heard good things about Arc and their bracket looks good.
Check out titanwirelessonline.com also. I think they sell some CPE kits and may have more options to look at.
normis
Mon Dec 08, 2008 9:01 am
Poynting also makes very good quality products. They have been to some MUMs as well as ARC. They both are very good choices.
hgb
Mon Dec 08, 2008 3:37 pm
Ok , i should try both of ARC and poynting and then deciding which is which ...
but ARC has 23dbi patches ant where poynting has the max of 19dbi in 5GHz
thanks to all ...
Tanker
Thu Dec 11, 2008 3:17 pm
We have hundreds of the Poynting products installed.
Rock solid - well made...
/T
Muqatil
Trainer
Trainer
Thu Dec 11, 2008 3:21 pm
http://www.mars-antennas.com/item/g_ant ... _1-43.html
Awesome mount-kit for an easy installation.. and 22dbi antenna...
Renato Bernardi
skype: medtech5
Tanker
Thu Dec 11, 2008 3:32 pm
ahem....
... also any other alternative for client CPE "enclosure + antenna" they must fit RB411 ...
8)
Muqatil
Trainer
Trainer
Thu Dec 11, 2008 3:36 pm
they fit... i got a lot of them with rb411 in it 8)
Renato Bernardi
skype: medtech5
JR
Fri Dec 12, 2008 4:38 pm
Vpol only! :(
Muqatil
Trainer
Trainer
Fri Dec 12, 2008 5:09 pm
You can use them with Hpol just rotate it by 90°
Renato Bernardi
skype: medtech5
hgb
Sat Dec 13, 2008 9:54 pm
By the way guys , are you using dual polarization antennas for antenna divirsity "if it's already featured in ROS" issues to receive the clearer signal if multipath issue happens in the way , Or you are using dual pol antennas to use Dual NStream and reduce the cost of using 2 physical antennas ?
or something else ? :X
thanks .
roc-noc.com
Forum Veteran
Forum Veteran
Sun Dec 14, 2008 8:14 pm
http://www.roc-noc.com/home.php?cat=18
Built to order ARC Wireless Gen II with Mikrotik RB411, A or AH and choice of radio card. The quality is much higher than the Rootennas that we have used in the past.
I have installed several of these over the past month. My favorite was 4.5 mile 3.65GHz PtP link using RB411AH. I am seeing 20.5Mbps tcp in both directions with 10 to 15% cpu load (while running bandwidth test locally).
Tom
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
hgb
Mon Dec 15, 2008 1:48 am
Good choice roc-noc.com , the 23dbi 5ghz has been added reciently coz i checked your web site before 3 days it wasn't there :D
But is it the dual pol ARC antenna or the single pol ?
Also no one answered me here :
thanks ...
RK
Long time Member
Long time Member
Sat Dec 27, 2008 9:11 am
I have to ask the obvious. What about the Rootenna Rootenna (a.k.a. the PacWireless one)?
RB411 fit just fine in them.
tgrand
Long time Member
Long time Member
Sat Jan 03, 2009 12:03 am
You soon change your mind on the roots once you find one full of water.
Users browsing this forum: tunarker and 33 guests
