lavv17
multicast when AP is in bridge mode
Mon Dec 29, 2008 8:38 am
Hi!
I have a problem with OSPF on point-to-point wireless links. I have determined that the reason is losing multicast packets when they are sent from AP to the client. The AP is in bridge mode (single client).
So the question is: is it possible to change multicast sending mode when AP is a bridge, so that normal "reliable" send mode is used for multicast?
lavv17
Re: multicast when AP is in bridge mode
Fri May 25, 2012 6:17 pm
Thanks for multicast-helper setting!
JorgeAmaral
Trainer
Trainer
Mon May 28, 2012 12:19 am
Hi!
I have seen that this is a common issue with wireless links that can be easily fixed by using network type nbma.
WirelessRudy
Fri Jun 29, 2012 1:45 am
What is 'multicast helper' doing?
What is "normal 'reliable' send" mode?
What is network type nbma?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
janisk
Fri Jun 29, 2012 8:28 am
Users browsing this forum: No registered users and 27 guests
