MUM Europe 2020
iam8up
Netinstall won't install
Tue Dec 30, 2008 12:56 am
I'm using an RB532 and last week I plugged this router in and found that it wouldn't boot. Come to find out RouterOS is gone and it is trying to pull DHCP on the ether1 port.
Using the console I get this much...
RouterBOOT booter 2.6
RouterBoard 532
CPU frequency: 399 MHz
  Memory size:  32 MB
Press any key within 2 seconds to enter setup..
kernel not found
trying bootp protocol... OK
Got IP address: 192.168.10.15
resolved mac address 00:16:36:6A:49:3A
transfer started ...................... transfer ok, time=1.31s
setting up elf image... OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
mac-address: 00:0C:42:08:D2:3B
software-id: UMJD-3TT key:
RtGc4WgrKW9jEr9rsIaFf02tManqAZL0HY/yGFDXIx6KCL+GHuhZVKzHAxU7Y7/Jr96GAgP+eLbqUMqbVYQqAA==
Waiting for installation server...
Found server at 00:50:56:C0:00:08
Formatting disk...
ERROR: could not format partitions
Press ENTER to reboot
sergejs
Re: Netinstall won't install
Tue Dec 30, 2008 3:25 pm
Try to upgrade RouterBOOT (RouterBOARD) firmware, it is possible in the following way,
run Hyperterminal program (Windows) or Minicom (Linux),
1) switch on the RouterBOARD, hit any key to enter to the RouterBOOT;
2) click 'g' - upgrade firmware;
3) select 's' - upgrade firmware over serial port (use option Send File from
HyperTerminal program), use Xmodem protocol.
iam8up
Fri Jan 02, 2009 9:47 pm
Do you know of an application that I can do this in Linux? Using Fedora/Gnome.
iam8up
Fri Jan 02, 2009 11:21 pm
Using a Windows machine I copied routeros-rb500-2.9.51.npk via serial and did netinstall with ethernet and it complains...
Upgrade firmware options:
   e - upgrade firmware over ethernet
   s - upgrade firmware over serial port
your choice: e - upgrade firmware over ethernet
transfer started ...................... transfer ok, time=1.20s
invalid upgrade file id
aaa
Sat Jan 03, 2009 2:11 pm
Hit any key and goes to BIOS , then format NAND , then "yes" And last try put RouterOS by Netinstall.
Helpful can be latest BIOS upgrade via /system routerboard upgrade. It seems it's 2.18 or 2.19 version.
roc-noc.com
Forum Veteran
Forum Veteran
Sat Jan 03, 2009 6:17 pm
Serge was suggesting that you upgrade the firmware aka BIOS. You are trying to use a RouterOS image not a firmware image.
Try this image which is correct for a RB532:
http://www.routerboard.com/files/rb-2.1 ... 4-2.13.fwf
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
roc-noc.com
Forum Veteran
Forum Veteran
Sat Jan 03, 2009 6:21 pm
888-762-5662
iam8up
Thu Jan 15, 2009 1:07 am
I knew that the firmware was part of the NPKs - didn't know it came separate. How did you find that link?
normis
Thu Jan 15, 2009 11:00 am
http://www.routerboard.com/comparison_archive.html
And by the way, that's an old link, here is the new one:
http://www.routerboard.com/files/rb-2.1 ... 0-2.18.fwf
iam8up
Sun Jan 25, 2009 10:24 am
Awesome - looks like I am good to go. Thank you very much!
letabawireless
Wed Aug 27, 2014 1:11 pm
I have a board with a blown ether1 port. The POE still works, so I can use it, but I can't make netinstall use ether2 instead of ether1. Is there any way, i can recover this board ?
labalaba
Sat Nov 08, 2014 1:43 pm
me to, netinstall only working on ether 1, can't do netinstall on ether 2/3/4/5. i need clarification on this issue, can i do netinstall on other ether. i already read wiki, forum and manual, i cant get any answer for this.
btw, i do netinstall on ether 1 then do quick setup, quick setup default to ether 1 and ether 2. hm... i would like to install mikrotik from ether 4/5 then do quick setup for ISP and LAN on ether 1 and 2.
something like
ether 1 -> plug ISP line
ether 2 -> plug LAN line 1
ether 3 -> plug LAN line 2
ether 4 -> netinstall from laptop/PC
ether 5 -> netinstall from laptop/PC
new router didn't have serial console, i like serial console for install, maybe mikrotik must provide one port/ether for install or USB port for install (replacing serial port), i like serial console
btw i also want to rename mikrotik software version, can i do this? i dont want people know what routher i'm using.
jarda
Mon Nov 10, 2014 9:20 am
I already asked for this in feature request: http://forum.mikrotik.com/viewtopic.php?f=1&t=90689.
You can support it...
Users browsing this forum: Google [Bot] and 10 guests
