briane
AP or CPE problem?
Thu Jan 08, 2009 2:57 pm
Below is the Registration tab of my Mikrotik AP.
The Mikrotik devices cannot access the Internet or the rest of the network. The Laptop running on it's internal wireless card accesses the Internet and the rest of the network.
I cannot see this as being an AP config issue, but the CPE's are so basic in setup I cannot fathom the problem.
Any suggestions?
Brian
Skype: brian.ellse
normis
Re: AP or CPE problem?
Thu Jan 08, 2009 2:58 pm
did you configure routing or NAT?
briane
Thu Jan 08, 2009 3:34 pm
AP has routing as indicated below. The 192.168.0.1 is the DLINK Hub wuith the Internet WAN connection. 192.168.0.2 is the Ether1 interface on the AP.
The bridge is setup as:
The IP Addresses :
No NAt routing setup.
Hope this info helps you to help me fix this darned problem :D
Regards
Brian
Skype: brian.ellse
briane
Thu Jan 08, 2009 6:18 pm
I have a feeling this may be relevant to the problem
This only shows the machines connected to the bridge via the Ether1 interface. The WLAN connects are not showing. Still doesn't explain why the wireless enabled laptop works fine through the AP and the two Mikrotik CPE's dont.....
Regards
Brian
Skype: brian.ellse
dawam
Trainer
Trainer
Thu Jan 08, 2009 9:41 pm
Your AP only have routing define to 192.168.0.0/24. Probably you need to define 0.0.0.0/0
Tbird
Fri Jan 09, 2009 9:15 pm
dawam is right - the default gateway is wrong. The entry with AS (Active Static) should be Destination = 0.0.0.0/0 (this means ANY) and Gateway = 192.168.0.1. That means that gateway for any traffic is 192.168.0.1 - the D-link - that's what you probably want...
briane
Sat Jan 10, 2009 8:29 am
Thanks guys, problem sorted...but not by me. I gave somebody remote access and he fixed the AP for me. Many thanks for all the responses from the forumites here.
Brian
gimmepatiencequickly
Wed Jan 14, 2009 10:57 pm
Hello Brian,
Suggestion: Could you tell us the AP problem in the first place, and perhaps a solution?
Thank you
Defer not till tomorrow to be wise, tomorrow's sun to thee may never
rise.
--- William Congreve
Users browsing this forum: No registered users and 28 guests
