soleed
wireless client not connecting
Sat Jan 17, 2009 4:11 pm
please i have a problem connecting from a wireless client to a Ap Bridge my configurations are likefollow and signal is -85
base
 interface wireless> pr
 0    name="wlan1" mtu=1500 mac-address=00:18:E7:0B:BA:CB arp=enabled
      disable-running-check=no interface-type=Atheros AR5213
      radio-name="CREATIVEAK" mode=ap-bridge ssid="CREATIVEAK" area=""
      frequency-mode=superchannel country=japan antenna-gain=0 frequency=2327
      band=2.4ghz-b scan-list=2327 rate-set=default
      supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
      supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
                          54Mbps
      basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
      ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
      periodic-calibration=default burst-time=disabled dfs-mode=none
      antenna-mode=ant-a wds-mode=static wds-default-bridge=none
      wds-ignore-ssid=no update-stats-interval=disabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=default
      disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
      compression=no allow-sharedkey=no
client
 0    name="wlan1" mtu=1500 mac-address=00:18:E7:0B:BA:C1 arp=enabled
      radio-name="0018E70BBAC1" mode=station-wds ssid="CREATIVEAK" area=""
      band=2.4ghz-onlyg scan-list=2327 rate-set=default
                          54Mbps
jwcn
Re: wireless client not connecting
Sat Jan 17, 2009 6:49 pm
-85 is not enough signal.
daffster
Mon Jan 19, 2009 10:33 pm
You have your client radio set to station-wds. This will not connect to an ap-bridge.
Change it to station mode.
Users browsing this forum: No registered users and 47 guests
