MUM Europe 2020
jmoore
Replacing Deliberant with Mikrotik
Thu Jan 29, 2009 3:58 am
We have an DLB 2700 w/ omni in the field for one of our broadcast sites. There are approximately 25 customers on this AP. Each customer is using a different brand of WiFi equipment from Deliberant, Proxim, YDI, you name it. I am needing more control at the access point level bandwidth control, firewall control, better CPE stats. I am curious if the following things are possible:
1. Bandwidth Control based on customer MAC address since we run DHCP and the IP will change often?
2. Write a firewall to block unwanted Netbios and other traffic on the Wireless Interface to keep wireless Clients from talking to each other and passing garbage back and forth
3. Hardware wise I am Looking at using RB433 w/ XR2 with level 3 license in place of the above setup any issues you can think of?
Joe
jmoore
Re: Replacing Deliberant with Mikrotik
Fri Jan 30, 2009 6:42 pm
I know somebody on this list is using Mikrotik for a wireless AP and can answer the questions I posted?
Joe
ericsooter
Fri Feb 06, 2009 5:45 pm
I am doing all are AP's and some CPE's with Routerboards. As for bandwidth control, We do all ours with PPPoE/radius. I'm pretty sure you can limit bandwidth via mac address. I have never done this; but I would guess you would mangle the traffic by mac address, and then put the mangle in a simple queue.
Firewall rules are extremely flexible. You can pretty much block whatever you want. There are even Layer 7 deep packet rules that can be applied. I recommend you go to the Mikrotik demo router and look at the firewall rules, they have a pretty good set of rules for common viruses and worms.
The basic license should be fine. I think the only time you need higher is if you have over 200 pppoe/hotspot/etc. connections. Not exactly sure on the number, it might be higher.
Overall, you get an extreme amount of control over the behavior of your AP/CPE.
Eric
illiniwireless
Sat Feb 14, 2009 12:10 pm
you have to get a level 4 license to operate as an ap
roc-noc.com
Forum Veteran
Forum Veteran
Sun Feb 15, 2009 4:50 pm
RB433 ships with a Level 4 license. RB433AH ships with Level 5 license.
You need a Level 4 or greater for AP. Not sure how your RB433 ended up with Level 3.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
miahac
Long time Member
Long time Member
Sun Feb 22, 2009 11:06 pm
Yes to all.
Everything you ask for can be done in more than one way.There is a small learning curve as there is no one way or right way to do anything with MT. I wish someone would come up with officially supported configurations, or setup scripts. The wikis are a great start.
You will need the level 4 license but thats great because the 433 comes with it no extra charge.
Network Administrator
Kansas Hosting and Wichita Data Centers
Users browsing this forum: Bing [Bot] and 32 guests
