I have a working 5GHz-turbo wds link:
[admin@MikroTik] > /interface wireless print detail
0 R name="wlan1" mtu=1500 mac-address=00:0X:XX:XX:XX:XX arp=enabled interface-type=Atheros AR5413 mode=ap-bridge ssid="xxx" frequency=5800
band=5ghz-turbo scan-list=default antenna-mode=ant-a wds-mode=static wds-default-bridge=bridge1 wds-ignore-ssid=no default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
and
[admin@Miki] > /interface wireless print detail
0 R name="wlan1" mtu=1500 mac-address=00:0X:XX:XX:XX:XX arp=enabled interface-type=Atheros AR5413 mode=station-wds ssid="xxx"
frequency=5800 band=5ghz-turbo scan-list=default antenna-mode=ant-a wds-mode=static wds-default-bridge=bridge1 wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
[admin@Graba] >
when I change to : /interface wireless set wlan1 band=5ghz
on both side, the link is disconnected and doesn't link anymore.
Anybody knows why?
regards,
