MUM Europe 2020
InoX
A new bug in 3.22?!
Sun Mar 22, 2009 3:57 pm
after the upgrade to 3.22...RB411 as AP with different clients like Edimax, Trendnet.
enk
Re: A new bug in 3.22?!
Sun Mar 22, 2009 9:53 pm
describe your problem in email for support, also attach supout.rif file.
as known as shados.
blog: http://betep.wpl.ru
A karma increase would be cool if you think I earned it.
RK
Long time Member
Long time Member
Mon Mar 23, 2009 8:27 am
What did you see in that field with an older version of routeros?
Could it be simply that the clients are reporting incorrect values?
InoX
Mon Mar 23, 2009 8:42 am
it was working properly until 3.22
Kenneth
Mon Mar 23, 2009 9:28 am
I've noticed the same thing on our 411 AP, all clients running MikroTik (133's & 411's).
Signal strengt we're flying from -50 to -1234556767.
I've downgraded fast as heck :)
InoX
Tue Mar 24, 2009 12:15 am
I hope this will be fixed soon
skillful
Trainer
Trainer
Tue Mar 24, 2009 12:43 am
I have noticed that this problem only occur when non Mikrotik or ROS systems connect to a to an AP running ROS 3.22.
You do see the problem when two systems running Mikrotik ROS connect.
InoX
Tue Mar 24, 2009 2:53 am
I've seen on a mikrotik bridge for one second and then the signal is normal again, not only on non mikrotik.
taglio
Sun Mar 29, 2009 12:28 am
I can confirm that this bug exist also with a AP mikrotik 3.22 [433AH] with a CM9-GP and a windows client connect to it:
.mhavoc world
uldis
Sun Mar 29, 2009 7:49 pm
this will be fixed in v3.23
lucapilosu
Tue Apr 07, 2009 12:01 pm
Do you know when ROS 3.23 will be released?
Have you got any roadmap about that?
Thanks,
Luca
normis
Tue Apr 07, 2009 12:07 pm
If will be released when all the fixes are done
moengoet
Tue Apr 28, 2009 6:55 pm
3.23 did fix it...but it fix the problem by having a 'blank' field of TX :(
uldis
Wed Apr 29, 2009 11:48 am
It should be blank. It will only show the TX info if on the other end will be RouterOS, as the other end sends this info.
boardman
Wed May 13, 2009 9:41 pm
Or Nanostation
Regards
JB
Users browsing this forum: lpt2007 and 38 guests
