Rbj
how select frequency ?
Mon Mar 30, 2009 11:26 pm
hello my dear
this picture of frequency usage !
how we select good channel for my clients ?
note:curve moving increase and reduce (what is the better thing ?
please give me information about pic in down :)
thanx
normis
Re: how select frequency ?
Tue Mar 31, 2009 9:26 am
well .. use 2427MHz and let it be :)
jpjust
Tue Mar 31, 2009 5:13 pm
So, channel usage is more important than noise? I've made some tests here and found out that noisy channels with few networks are better than clean channels with lots of networks. Am I right?
Joao Paulo Just
RG3.Net and Justsoft
FCP - Furukawa Certified Professional
Blog - jpjust.blogspot.com
taglio
Tue Mar 31, 2009 5:32 pm
I personal prefer a balance between noise floor and freq usage.
.mhavoc world
normis
Wed Apr 01, 2009 9:14 am
It all depends, there is no definitive andwer. Just test and see.
janisk
Thu Apr 02, 2009 2:19 pm
noise = some random radio interference on the frequency you are listening on, all unrecognized signal is thrown here
usage = 802.11 frames that can be recognized.
so if you have device that does no understand either of signals - it all will be noise, well, after all, it is noise.
Aug
Thu Apr 02, 2009 5:05 pm
I prefer to use scan.
It give you a better look at whats out there.
Also you can sort by signal strenght, frequency, etc.
Aug
angboontiong
Fri Apr 03, 2009 4:49 am
I would suggest..
You should try 1 by 1 channel and see which one can provide more high throughput with good ping latency...
Users browsing this forum: No registered users and 21 guests
