kellogs
determine antenna a or b
Mon Apr 06, 2009 5:14 pm
Good Day,
is it possible to view if the radio is connected to antenna a or b from winbox?
Thank you
remuss
Re: determine antenna a or b
Mon Apr 06, 2009 6:48 pm
i don't think that this is possible but u must know what antenna is connected when you have assessable the equipment.
Best Regards Remus
beny30
Fri Apr 17, 2009 3:23 pm
If you have much more stronger signal than in another antena does it not mean the this antena you are using e.g. I tried in antena a I got -83 % I tried in antena b I got -53 % which one to use I think that I am using antena b but not sure.
valypetre
Fri Apr 24, 2009 10:07 am
be sure
SurferTim
Fri Apr 24, 2009 5:46 pm
Most wireless cards have the antenna connectors labeled "main" and "aux". Normally, "main" is ant-a. I do know of one exception. The Ubiquiti SR2 mmcx (big) connector is ant-b.
conjurer
Mon Apr 27, 2009 4:39 pm
Also compex WLM54G main is antena b.
Also i think aux is obsolete. Well maybe if you have mmcx and ipex connectors, then it has some advantages.
Users browsing this forum: Bing [Bot] and 37 guests
