Hi!
We have nearly the same problem. We're an ISP in Austria and have 1000+ customers with 100/133/411/433-clients.
As now we're using the above mentioned method to do a scan (with putty as telnet-client).
But we have a major problem with it: The output seems missing some lines, the result looks like this:
[admin@MT433-Clientname] /interface wireless> scan 0
Flags: A - active, B - bss, P - privacy, R - routeros-network, N - nstreme
ADDRESS SSID BAND FREQ SIG NF SNR RADIO-NAME
scan not running6:5D:DE PTP-xyz... 5ghz 5580 -78 -98 20 PTP-AP
ABPR 02:0B:6B:DD:12:84 SSID1 5ghz 5580 -76 -98 22 AP-Customers1
ABPR 02:0B:6B:DD:12:85 SSID2 5ghz 5580 -77 -98 21 AP-Customers1
As you can see theres one line complety overwritten with a blank line (directy under ADDRESS) and at the second one there is 'scan not running' in the beginnig ...
(if you wonder about the same channels: the AP has 1 PTP-Link and two virtual AP's, the new, important AP cannot be seen because its overwritten by the blank line)
The only chance to get the full output is to use the logging feature of putty (into a file). If you check the outputted file then you'll recognize that there's a lot more output than in the telnet windows appears.
Now there's my question: Is there any way to get the full output to the screen without logging into a file everytime?!?
BTW: a solution via Winbox would be REALLY great!
Thank you in advance for some good ideas/solutions!
