MUM Europe 2020
linkston
Outdoor TEST RB411AH +R52n Distance 1.51 KM + Mars Antennas
Wed Jun 10, 2009 12:31 am
2x RB411AH + R52n Distance 1.51 KM + Mars Antennas DUAL 23DBI
Radio TX only 10dBm in center CITY KAUNAS!!!!!
See all in the pictures
First resume:
best settings: first AP second station bridge with EOIP tunnel
bugs: not work with WDS mode and nstreem
i will post configs in this week.
link: distance:
http://maps.google.com/maps/ms?ie=UTF8& ... a9a2725a52
TEST pictures:attached
best regards to Normis http://www.frineta.lt TEAM
in few days i will POST all configs mounting process...etc...
RK
Long time Member
Long time Member
Re: Outdoor TEST RB411AH +R52n Distance 1.51 KM + Mars Antennas
Wed Jun 10, 2009 3:04 am
Can you run a TCP test?
linkston
Wed Jun 10, 2009 3:14 am
realy link is not finished yet so it is not finaly results and i will post updates later! remember that test are rb to rb, 411ah is has not enouth CPU power to run normal TCP tests, later i i would test bridge ON PC to PC
Look here:
file attached on first post
N411AH.zip [977.9 KiB]
ste
Wed Jun 10, 2009 8:09 am
TCP-Test is useless for 11N. I've tested with 2x411AH connected with R52N and
2xRB450G directly connected with Cable. Both max out at ~80MBit TCP.
So it's a CPU-Test and not a test of connection speed.
UDP gives 220MBit and ~500MBit.
Stefan
linkston
re: Outdoor TEST RB411AH +R52n Distance 1.51 KM + Mars Anten
Wed Jun 10, 2009 9:39 am
TOWER PICTURES
attached to zip:
ribaro
Tue Jun 16, 2009 11:29 pm
Can you run UDP bandwith test in both directions with this setup? Do you reach 100 mbps full duplex?
infowest
Thu Jun 18, 2009 9:33 pm
Can you clarify this?
Do you mean that nstreme doesn't work, and wds mode doesn't work, or do you mean wds doesn't work with nstreme?
I am trying a wds nstreme link not getting great results - frequent disconnects. WDS without nstreme seems somewhat better but 2-way speed tests kill the link or take it down to unusable speeds.
Randy
Users browsing this forum: No registered users and 14 guests
