MUM Europe 2020
ahmedramze
XR5 and Super Channels
Sun Jun 14, 2009 5:46 am
Hi
Im use 2 Mikrotik box RB600 with 2 XR-5 600mw with distance 10Km , i have on AP router
[admin@UPLINK] interface wireless registration-table> print
# INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL... TX-RATE
0 wlan1 00:15:6D:10:11:6E no -57dBm... 48Mbps
[admin@DownLINK] interface wireless registration-table> print
0 wlan1 00156D101194 00:15:6D:10:11:94 yes -58dBm... 48Mbps
only one frequincy (5745) i can use it all chanels are in use , i upgrade licence to extra chanels.
The problem when i set both ends to Freq=5750 or 5740 or any freq from 5320-5745 , i cant find the signal and no link between them.
when i did
[admin@Down-Link] interface wireless info> print
0 interface-type=Atheros AR5213
chip-info="mac:0x5/0x9, phy:0x43, a5:0x36, a2:0x0, eeprom:0x4008"
pci-info="00:05.0" capabilities=tx-power-control,ack-timeout-control,
virtual-ap,alignment-mode,noise-floor-
control,scanning,burst-support,nstreme,
sniffing,compression,power-channel
default-periodic-calibration=enabled
i have all frequinces from 4000 to 6000 Ghz,
My configuration in UPLINK its AP + Dyn-WDS+Nstreme (i try 5Ghz and -10Mhz and -5Mhz and turbo ) and downlink its Station-WDS , I need to send more bandwith the Bandwith now its maximum 8Mb/8Mb updown , i need to solve the wirelss interferance ( this channel used about 1% when i monitor freq. and other chaneels bout 20-30%)
Regards
Nuke
Re: XR5 and Super Channels
Sun Jun 14, 2009 9:11 pm
Had the same problem, its a undocumented feature you can call it. When using a channel outside the normal band, you need to add that frequency(or range) in under "scan-list".
ahmedramze
Sun Jun 14, 2009 10:06 pm
This is when i Select Frequincy Mode = Reg. domain.
[admin@Down-Link] interface wireless> info print
supported-bands=5ghz,5ghz-turbo,5ghz-10mhz,5ghz-5mhz
5ghz-channels=5180:0,5200:0,5220:0,5240:0,5260:0,5280:0,5300:0,5320:0,
5745:0,5765:0,5785:0,5805:0,5825:0
5ghz-turbo-channels=5210:0,5250:0,5290:0,5760:0,5800:0
5ghz-10mhz-power-channels=5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,
5215:0,5220:0,5225:0,5230:0,5235:0,5240:0,5260:0,
5265:0,5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,
5300:0,5305:0,5310:0,5315:0,5320:0,5745:0,5750:0,
5755:0,5760:0,5765:0,5770:0,5775:0,5780:0,5785:0,
5790:0,5795:0,5800:0,5805:0,5810:0,5815:0,5820:0,
5825:0
5ghz-5mhz-power-channels=5180:0,5185:0,5190:0,5195:0,5200:0,5205:0,5210:0,
5825:0
and I pay for extra channel licence
[admin@Down-link] system license> print
software-id: "7E8C-3TT"
upgradable-to: v5.x
nlevel: 5
features: extra-channels
When I select Super Channel
5ghz-channels=4920:0,4925:0,4930:0,4935:0,4940:0,4945:0,4950:0,4955:0,
4960:0,4965:0,4970:0,4975:0,4980:0,4985:0,4990:0,4995:0,
5000:0,5005:0,5010:0,5015:0,5020:0,5025:0,5030:0,5035:0,
5040:0,5045:0,5050:0,5055:0,5060:0,5065:0,5070:0,5075:0,
5080:0,5085:0,5090:0,5095:0,5100:0,5105:0,5110:0,5115:0,
5120:0,5125:0,5130:0,5135:0,5140:0,5145:0,5150:0,5155:0,
5160:0,5165:0,5170:0,5175:0,5180:0,5185:0,5190:0,5195:0,
5200:0,5205:0,5210:0,5215:0,5220:0,5225:0,5230:0,5235:0,
5240:0,5245:0,5250:0,5255:0,5260:0,5265:0,5270:0,5275:0,
5280:0,5285:0,5290:0,5295:0,5300:0,5305:0,5310:0,5315:0,
5320:0,5325:0,5330:0,5335:0,5340:0,5345:0,5350:0,5355:0,
5360:0,5365:0,5370:0,5375:0,5380:0,5385:0,5390:0,5395:0,
5400:0,5405:0,5410:0,5415:0,5420:0,5425:0,5430:0,5435:0,
5440:0,5445:0,5450:0,5455:0,5460:0,5465:0,5470:0,5475:0,
5480:0,5485:0,5490:0,5495:0,5500:0,5505:0,5510:0,5515:0,
5520:0,5525:0,5530:0,5535:0,5540:0,5545:0,5550:0,5555:0,
5560:0,5565:0,5570:0,5575:0,5580:0,5585:0,5590:0,5595:0,
5600:0,5605:0,5610:0,5615:0,5620:0,5625:0,5630:0,5635:0,
5640:0,5645:0,5650:0,5655:0,5660:0,5665:0,5670:0,5675:0,
5680:0,5685:0,5690:0,5695:0,5700:0,5705:0,5710:0,5715:0,
5720:0,5725:0,5730:0,5735:0,5740:0,5745:0,5750:0,5755:0,
5760:0,5765:0,5770:0,5775:0,5780:0,5785:0,5790:0,5795:0,
5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,5830:0,5835:0,
5840:0,5845:0,5850:0,5855:0,5860:0,5865:0,5870:0,5875:0,
5880:0,5885:0,5890:0,5895:0,5900:0,5905:0,5910:0,5915:0,
5920:0,5925:0,5930:0,5935:0,5940:0,5945:0,5950:0,5955:0,
5960:0,5965:0,5970:0,5975:0,5980:0,5985:0,5990:0,5995:0,
6000:0,6005:0,6010:0,6015:0,6020:0,6025:0,6030:0,6035:0,
6040:0,6045:0,6050:0,6055:0,6060:0,6065:0,6070:0,6075:0,
6080:0,6085:0,6090:0,6095:0,6100:0
5ghz-turbo-channels=4920:0,4925:0,4930:0,4935:0,4940:0,4945:0,4950:0,4955:0,
5ghz-10mhz-power-channels=4920:0,4925:0,4930:0,4935:0,4940:0,4945:0,4950:0,
4955:0,4960:0,4965:0,4970:0,4975:0,4980:0,4985:0,
4990:0,4995:0,5000:0,5005:0,5010:0,5015:0,5020:0,
5025:0,5030:0,5035:0,5040:0,5045:0,5050:0,5055:0,
5060:0,5065:0,5070:0,5075:0,5080:0,5085:0,5090:0,
5095:0,5100:0,5105:0,5110:0,5115:0,5120:0,5125:0,
5130:0,5135:0,5140:0,5145:0,5150:0,5155:0,5160:0,
5235:0,5240:0,5245:0,5250:0,5255:0,5260:0,5265:0,
5270:0,5275:0,5280:0,5285:0,5290:0,5295:0,5300:0,
5305:0,5310:0,5315:0,5320:0,5325:0,5330:0,5335:0,
5340:0,5345:0,5350:0,5355:0,5360:0,5365:0,5370:0,
5375:0,5380:0,5385:0,5390:0,5395:0,5400:0,5405:0,
5410:0,5415:0,5420:0,5425:0,5430:0,5435:0,5440:0,
5515:0,5520:0,5525:0,5530:0,5535:0,5540:0,5545:0,
5550:0,5555:0,5560:0,5565:0,5570:0,5575:0,5580:0,
5585:0,5590:0,5595:0,5600:0,5605:0,5610:0,5615:0,
5620:0,5625:0,5630:0,5635:0,5640:0,5645:0,5650:0,
5655:0,5660:0,5665:0,5670:0,5675:0,5680:0,5685:0,
5690:0,5695:0,5700:0,5705:0,5710:0,5715:0,5720:0,
5795:0,5800:0,5805:0,5810:0,5815:0,5820:0,5825:0,
5830:0,5835:0,5840:0,5845:0,5850:0,5855:0,5860:0,
5865:0,5870:0,5875:0,5880:0,5885:0,5890:0,5895:0,
5900:0,5905:0,5910:0,5915:0,5920:0,5925:0,5930:0,
5935:0,5940:0,5945:0,5950:0,5955:0,5960:0,5965:0,
5970:0,5975:0,5980:0,5985:0,5990:0,5995:0,6000:0,
6075:0,6080:0,6085:0,6090:0,6095:0,6100:0
5ghz-5mhz-power-channels=4920:0,4925:0,4930:0,4935:0,4940:0,4945:0,4950:0,
roc-noc.com
Forum Veteran
Forum Veteran
Mon Jun 15, 2009 12:14 am
On the station (also needs superchannel license) you need to create a scan list that includes the frequencies that you want to connect with. The default scan list only finds regulation frequencies.
Something like:
> interface wireless add scan-list=5200-5900
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
ahmedramze
Mon Jun 15, 2009 12:25 am
Yessssssssss
thanks , its work just i add scan list=5000-6000
cylent
Fri Jul 03, 2009 12:04 pm
hmm. thats funny. when i do this i get a virtual ap added thats disabled.
even if i enable it i cant see an ap that i set to 5745 for example. what gives?
ahmedramze
Fri Jul 03, 2009 12:12 pm
Hi
Sorry I not mean ADD , i was use win box for terminal you can do this
set wlan1 scan-list=3000-7000
Regards :D
cylent
Fri Jul 03, 2009 2:52 pm
Thank you. That makes sense.
I always wondered what i should populate the scan-list box with. now i know and i am able to use more channels.
Ibersystems
Mon May 02, 2011 1:55 pm
Its possible to use channels from 4,870 to 4,940 with XR5? Wich is the best card to achieve this?
thanks,
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
Users browsing this forum: Google [Bot], RTouris, YakovGusev and 45 guests
