dunga
HOW TO UPGRADE A ROUTER BOARD
Fri Jun 26, 2009 3:36 pm
I am having some problems to upgrade the router board. I have a router board with version 2.9.46, with level 4 lincense in it but the chipset (atheros) version i do not know.
How do i determine the version or board version i am using, and the current upgrade link, cus i want to use the radio for AP and run Hotspot in it, but I could not get user manager We want to deploy it so that the receptionist can create accounts for users thru userman, witout going thru winbox.
thanks, your help will be appreciated.
mrz
Re: HOW TO UPGRADE A ROUTER BOARD
Fri Jun 26, 2009 3:44 pm
check
/system resource print
dunga
Re: Help on hotspot for wlan
Mon Jun 29, 2009 10:34 pm
Plz, I have configured the wlan to distribute the hotspot, yet it cannot display the log in page. If I remove or disable the hotspot, wireless connected computers will display. What is my area dat i did wrong.
Here is my wireless configurations
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:18:B8:F6 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name="000C4218B8F6" mode=ap-bridge ssid="ADEZ-HOTSPOT" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2.4ghz-b/g scan-list=default rate-set=configured
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
max-station-count=2007 ack-timeout=dynamic tx-power=17
tx-power-mode=all-rates-fixed noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
compression=no allow-sharedkey=no
while my firewall configuration is;
[admin@ADEZ INFOSYSTEM, LTD] ip firewall> nat print
0 chain=srcnat action=masquerade out-interface=ether1
1 ;;; masquerade hotspot network
chain=srcnat action=masquerade src-address=193.168.0.0/24
Plz ur help is needed
Users browsing this forum: No registered users and 16 guests
