MUM Europe 2020
illiniwireless
help needed using nstreme in ptmpt mode
Thu Jul 16, 2009 5:13 pm
Do you need to install wireless test package to use nstreme in point to multipoint mode.
netrat
Re: help needed using nstreme in ptmpt mode
Thu Jul 16, 2009 6:02 pm
No, but the CPEs have to be RouterOS with nstreme enabled.
illiniwireless
Thu Jul 16, 2009 6:52 pm
does it help to use wireless test package because i tried nstreme and my ping times went through the roof (40-400 ms) all the time without data and without nstreme pings were (1-10 ms)
netrat
Thu Jul 16, 2009 8:38 pm
Pings will be more stable once you start flowing data across the link.
jmpiorno
Thu Jul 16, 2009 10:39 pm
Hello, in my case I have several nodes with 40 - 50 - 60 CPE Nstreme enabled ping is 20-300ms, now I'm trying to 1 node has 50 CPE Nanoloco5 and disabled Nstreme see is that ping 2-7 ms.
Mikrotik'd do something Nstreme to support more clients and better quality of ping :?
Muqatil
Trainer
Trainer
Fri Jul 17, 2009 3:12 pm
Tell me if you get better results without wireless test..
50clients connected
2mbit offered
Renato Bernardi
skype: medtech5
illiniwireless
Sat Jul 18, 2009 6:54 am
thank you for all the replies and I think I will try wireless test package
Users browsing this forum: No registered users and 30 guests
