jmpiorno
When new Beta!!
Wed Jul 22, 2009 2:44 am
Mikrotik.
when launching the new beta ROS 4, we need 802.11N work better !
normis
Re: When new Beta!!
Wed Jul 22, 2009 8:46 am
what do you mean "work better" :D it's very good already!
jmpiorno
Re: When new Beta!!
Wed Jul 22, 2009 4:35 pm
no, not working properly, is very unstable, tends too many problems with the signal, especially when we work out in the lab has no problem
w0lt
Re: When new Beta!!
Wed Jul 22, 2009 10:59 pm
Normis, my iMac connection is very slow...much slower than a 52H version. I believe you acknowledged that connecting "N" to Macs were a problem, or have I misspoken?
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
normis
Re: When new Beta!!
Thu Jul 23, 2009 8:27 am
no, 802.11n with Macs was either working or not working. Don't worry, next beta has a new wireless driver, it should improve a lot of things.
jmpiorno
Re: When new Beta!!
Fri Jul 24, 2009 4:44 am
normis. you know when the new beta release?
normis
Re: When new Beta!!
Fri Jul 24, 2009 8:26 am
today probably
npbrasil
Re: When new Beta!!
Sat Jul 25, 2009 8:11 am
Hi Normis, in the changelog of 4.0 beta 4 there is no one single word about wireless changes or improvements. What was changed?
w0lt
Re: When new Beta!!
Sat Jul 25, 2009 2:24 pm
I've loaded the new beta, and am a bit disappointed. The "N" response of the AP is sluggish compared to standard B/G mode. However, for some reason the B/G mode seems to have perked up very nicely compared with the last beta. I am, still using a Apple iMac, so I'm not sure if that might be the reason for the sluggish "N" performance. It didn't connect at 5 GHz before, I'll try doing that today.
-tp
MTCNA - 2011
w0lt
Re: When new Beta!!
Mon Jul 27, 2009 8:31 pm
-tp
Well, it appears the problem with Apple connecting to 5 GHz-N mode still exists. I can connect to 5 GHz using B/G, but I was able to do that in the previous version as well.
-tp
MTCNA - 2011
uldis
Re: When new Beta!!
Tue Jul 28, 2009 10:22 am
We have also seen this problem. If you have some 5ghz N AP then we would need a wireless sniffer file from the moment when the wireless client (iMAC/MacBook Pro) successfully connects to that AP, then we could try to fix that.
Users browsing this forum: Bing [Bot] and 39 guests
