MUM Europe 2020
cylent
r52n tx power low?
Thu Jul 30, 2009 11:33 pm
hi all
i obtained the r52n minipci module and was told it was similar to the r52h but when i plugged into the 433ah and booted it up (after upgrading to 4beta and updating key) its tx power in 5ghz mode is only 18dBm.
from what i know 18 = 65mW ... this makes it nothing but a r52 with n capabilities.
according to this document http://www.routerboard.com/pdf/R52n.pdf the r52n is supposed to pump out 21dBm at 6mbit and 19dBm at 24mbit. so then why does it say 6=18 in the txpower box and the same for 54?
Is there something wrong or is this what the r52n really is?
uldis
Re: r52n tx power low?
Fri Jul 31, 2009 3:27 pm
if you use both chains at the same time you will be able to get 21dbm
Real
Fri Jul 31, 2009 9:09 pm
hi, i have same problem ,max 18db ,enabled tx rx chains 0,1
what is wrong ? what i have to change to get full output power ?
tomasz.skarupa
Thu Oct 08, 2009 5:09 pm
Sorry for my mimo-noobness, but 21 is not 25... where are the 4 dBs missing?
normis
Fri Oct 09, 2009 10:23 am
it's because you use two antennas at the same time. one card can't work on full power on both chains (antennas) at the same time. this is normal for MIMO
angboontiong
Fri Oct 09, 2009 4:37 pm
Possible it will have high power ASAP???
Users browsing this forum: No registered users and 26 guests
