ctech4285
corrupt sniffer files from rb433+routeros 3.28
Sat Aug 15, 2009 8:57 pm
I created a package file with the routeros, downloaded it via ftp and imported it to wireshark. i get wired error corrupt file errors. i tryed a few other programs and get the same result.
the changelog for 3.0beta7 states that: fixed wireless sniffer file format;
i have an rb433 with the newest routeros version installed (i think)
[admin@MikroTik] /system package> print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 X routing-test 3.28
1 dhcp 3.28
2 X ipv6 3.28
3 system 3.28
4 advanced-tools 3.28
5 routing 3.28
6 hotspot 3.28
7 security 3.28
8 routerboard 3.28
9 wireless 3.28
10 routeros-mipsbe 3.28
11 ppp 3.28
kind regards
snezan
sergejs
Re: corrupt sniffer files from rb433+routeros 3.28
Mon Aug 17, 2009 2:11 pm
Please, paste the exact command, which was used to create sniffer file.
Do you have the latest wireshark version ?
ctech4285
Mon Aug 17, 2009 8:53 pm
sure thing
i got the latest wireshark version
the error i get when opening the sniffer file is:
The capture file appears to be damaged or corrupt.
(pcap: File has 3405774848-byte packet, bigger then the maximum of 65535)
the file size is only 88KB
here are the sniffer settings i used
[admin@MikroTik] /interface wireless sniffer> print
multiple-channels: no
channel-time: 200ms
only-headers: no
receive-errors: no
memory-limit: 100
file-name: "test04"
file-limit: 10000
streaming-enabled: no
streaming-server: 192.168.30.127
streaming-max-rate: 0
[admin@MikroTik] /interface wireless sniffer> sniff
interface: wlan2
processed-packets: 720
file-size: 88869
file-saved-packets: 720
file-over-limit-packets: 0
memory-size: 100365
memory-saved-packets: 720
memory-over-limit-packets: 0
real-file-limit: 10000
real-memory-limit: 100
end then i used 'q' for quit
i attached the sniffer file, (it doesnt contain any private information)
test4.txt is the original file strait from the routerboard, i just added .txt so i could upload it
thank you for your help
ctech4285
Fri Aug 21, 2009 4:24 am
ok i upgraded
Flags: X - disabled
0 system 4.0beta4
1 dhcp 4.0beta4
2 user-manager 4.0beta4
3 multicast 4.0beta4
4 ipv6 4.0beta4
5 security 4.0beta4
6 routing 4.0beta4
7 hotspot 4.0beta4
8 mpls 4.0beta4
9 routerboard 4.0beta4
10 advanced-tools 4.0beta4
11 wireless 4.0beta4
same problem with corrupt sniffer files??!! bug?
how do i report bugs?
sergejs
Mon Aug 24, 2009 4:13 pm
Just tried the same settings on my RouterBOARD,
/system routerboard> print
       routerboard: yes
             model: "433AH"
     serial-number: "198501F09225"
  current-firmware: "2.21"
  upgrade-firmware: "2.20"
[admin@MikroTik] /system routerboard> /interface wireless sniffer print
        channel-time: 200ms
        only-headers: no
      receive-errors: no
        memory-limit: 10
           file-name: "SSSNIFFF"
          file-limit: 10
    streaming-server: 0.0.0.0
My file is opening correctly. Please contact support (support@mikrotik.com) with the attached support output file from the router.
ctech4285
Tue Aug 25, 2009 12:07 am
the file was getting corrupted during transfer, i transferred the file with winbox and had no problems at al, thank you.
Users browsing this forum: andkar and 28 guests
