wireless12
a humble request!!!!!
Wed Aug 19, 2009 4:17 pm
hii..
it would be great if mikrotik add a feautre where its shows airial distance between two mikrotik units in a point to point wireless link.
and also if it possible the distance of all CPE connected to a mikrotik AP-bridge.
thxxx..
normis
Re: a humble request!!!!!
Thu Aug 20, 2009 8:56 am
how would it know this distance :shock: ?
RK
Long time Member
Long time Member
Thu Aug 20, 2009 4:23 pm
Based on the dynamic ack timeout that it already calculates!
normis
Thu Aug 20, 2009 4:25 pm
bad links will be very very wrong based on ACK, and even good links will be not precise. what's the use of such imprecise information?
valypetre
Thu Aug 20, 2009 4:38 pm
alvarion has this feature. and it's very precise. I believe it tests the latency with different ack settings, chooses the best one and evaluates the distance. just a guess.
wireless12
Thu Aug 20, 2009 4:40 pm
hii..
i think radwin and motorla also got this feautre..
regards..
m4rk0
Thu Aug 20, 2009 4:49 pm
I can also confirm for Alvarion. And it's pretty precise...
http://www.mreza-wisp.ba/
Please, give Karma if I fix your problem
Certified MTCNA
uldis
Thu Aug 20, 2009 4:56 pm
I think they are not using 802.11 standard but some proprietary standard and with that maybe they can get more precise results.
Muqatil
Trainer
Trainer
Thu Aug 20, 2009 5:45 pm
i second this request.
Renato Bernardi
skype: medtech5
samir494
Wed Sep 02, 2009 2:10 pm
can anyone explain the case, calculation of ack setting and distance
Mistry Samir
Unique and Different
India
9920670022
Give me more Karma
jp
Long time Member
Long time Member
Fri Sep 04, 2009 4:34 am
Why do you want it to show the distance? So you don't have to draw a line between two points in google earth to see a distance?
Alvarion's implementation is very accurate. UBNT and trango are less accurate.
If MT used it, I'd want them to do more than just display it.
vik1988
Thu Aug 25, 2011 9:35 am
MT Added this feature in ROS 5+ by enabling NV2.
0ldman
Thu Aug 25, 2011 4:22 pm
This thread is nearly two years old.
Users browsing this forum: Google [Bot] and 17 guests
