wireless12
possible to carry or not?
Wed Sep 16, 2009 3:26 pm
hii..
i got a call to give 8 Mbps dedicated internet bandwith for a export house..
the arial distance between my POP and the Export house is 24 Km...LOS is clear.(i have got bandwidth already on single ethernet interface at my POP)
is it possible for mikrotik to carry 8 Mbps premium dedicated internet bandwidth...? if yes then which RB and mini pci shd be used..
thxxx
regards..
wireless12
Re: possible to carry or not?
Thu Sep 17, 2009 10:18 am
hello....i think the answer is no, bec everyone is silent...?
bad luck to me..
i was hoping mikrotik can do it..
regards..
normis
Thu Sep 17, 2009 10:23 am
of course it's possible, any RouterBOARD can do it, for example RB411AH. You will also need a R5H card, and a good antenna.
R5H is 5GHz only, so choose your card according to your requirements.
angboontiong
Thu Sep 17, 2009 12:31 pm
You should look for the solid parabolic antenna.
Users browsing this forum: No registered users and 33 guests
