rodolfo
Long time Member
Long time Member
how to adjust data rates?
Tue Sep 22, 2009 9:48 pm
Hi all.
I have some clients 5ghz connected to an AP.
I use all rb411 (H for AP) and R52 radio.
In some case, a "difficult" user (low signal, i.e. -84) experiece lots of disconnection.
Wath could be the effect of setting la lower data rate to the wlan of this user ?
could this give a better connection ?
thanks.
R
rodolfo
IZ0UQV
ctech4285
Re: how to adjust data rates?
Tue Sep 22, 2009 10:10 pm
it should not, you radio shoud automaticly ajust the data rate
but -84dbm is too low in my experiance for a stable conection
rodolfo
Long time Member
Long time Member
Wed Sep 23, 2009 10:55 am
In the graphic you can see the effect of limiting the data rate at cpe-side.
You see: tx and rx db remain costants but the ccq rise, and not more dosconnections:
My question is: limiting the data rate at CPE side, causes collateral effects AP side ?
thanks
rodolfo
IZ0UQV
normis
Wed Sep 23, 2009 10:56 am
lowering the data rates could make your link more stable, but really not in this case, the signal is just too bad. you need to find a better positioning for the antenna
rodolfo
Long time Member
Long time Member
Wed Sep 23, 2009 8:21 pm
thanks for the hint
is there any document I can read about the modulation behaviour of the radio ?
rodolfo
IZ0UQV
Users browsing this forum: No registered users and 15 guests
